How do I get a mic as stereo? it only has 1 input
i am using a mic and a preamp which is being inputted in the line in 1 of the digi002. I am using PTLE002 6.1.1 and it only records in 1 side of the stereo mix i put in PT. How can I make my single input mic into stereo?
Re: How do I get a mic as stereo? it only has 1 i
You can't. One mic with one element is mono, no matter how you slice it. You can copy the mono left track to the right track, but it's still mono, jsut 3db louder.
In order to record in stereo you need two mics. |
Thanks. At least if I copy it to the other side of the track, I can pan them and apply seperate effects.
No, you cannot apply spearate effects to the left and right of a stero track. You would need to copy it to another mono track to do this.
I see, thanks Where.
Many times I've recorded a mono mic (vocals) on a mono audio track. Then choose an stereo plug-in and when inserted the mono track changes to a stereo audio track
If you remove the stereo plug-in.....the track will go back to mono.
METAL LABS |
with your technics you won´t achieve true stereo, but i guess you guys know it.
O.R.S. - recording engineer - www.overdub.at |
True stereo or not, it's taking up a stereo audio track. Must be false stereo. This is just a technique we've used at home and in big facilities. I'm sure there's more scientificly thought out methods, like just using a stereo mic or two mics
METAL LABS |
the delay won't make the mono file stereo.
Well, here's the Cambridge Dictionary definition of:
stereo [Show phonetics] noun 1 [U] a way of recording or playing sound so that it is separated into two signals and produces more natural sound: The concert will be broadcast in stereo. ...any comments?
"Art is the means by which we contemplate our intuitive knowledge" |
Xmon Stereo 4 input? | Maskeeper | ICON & C|24 | 3 | 10-10-2013 04:25 AM |
stereo mic to mono input on m-box | driver8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-11-2011 09:25 AM |
Stereo Track with one input? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 3 | 03-29-2008 09:07 PM |
PT6.1 Stereo Aux Input plugin not recorded | mibo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-19-2003 01:37 AM |
stereo AS plugs w/ mono input | merz | Pro Tools TDM Systems (Mac) | 4 | 11-30-1999 01:55 AM |
