stereo mic to mono input on m-box
Hi all,
I want to use a cheap stereo microphone with mini-jack (came with a soundblaster...its probably a condensor mic) with my m-box. Tried a 1/8" stereo to 1/4" mono adapterplug with no luck. Also tried the phantompower-switch, didn't work. No sound from the m-box. This setup, with the little mike on a laptop with m-box just seemed very convenient to me for song writing. Is it possible at all? If not, are there other/better solutions? Of course I got better microphones but they're all dynamic [img]images/icons/rolleyes.gif[/img] . TIA |
Re: stereo mic to mono input on m-box
I think the little microphone needs phantom-power. I am not really sure, but i think the normal phantom-power will NOT work, but its worth a shot. Probably the little mic is not a dynamic microphone but an electret. Somehow that is the cheapest to produce, and they have surprisingly good quality.
What's that? - That's the machine that goes "pling". Bastiaan |
THNX Bastiaan,
Got myself a nice small sony electret mike. It sounds great! (for what I want with it) Only problem is: its stereo, I can use a stereo to mono plug...but wont that degrade the sound too much? |
THNX Bastiaan,
Does the mic take a battery? If you can, post a link to the website for the mic. That would give us a better idea of what you have. Then we could give you a solution to your problem.
Mitch |
Well, its a sony ECM-717 mic on a battery. It does work with the m-box.
But...its stereo! I want to record mono > how can I get the two channels from the mic into one? |
I don't know...but have you tried getting or using a monoplug adapter (single stripe) over the 1/4 jack (double jack) of your mike?
Backroom strum engineer/pick searcher--where is that rascal? Oh man!...where'd that track go? Tequila is evil!!!!!!!!!!!!! he he defretman |
Or make it mono in the box. Connect it stereo. Then create a stereo aux-track with both balance-sliders in the middle, and route that to a bus. The create a mono audiotrack, and set the input to that bus.
So the flow is: stereo mic -> stero aux -> mono bus -> mono audio channel Or only use one side of the stereo-mic. So connect it as if you where going to use it for stereo, but then only create a mono-audiotrack and record to that.
What's wrong with stereo anyway?
Punch In Audio Services www.punchin.nl Studio Engineering | Live Engineering | Location Recording | Composing |
i got additional questions for you guys. I just bought an M Box Mobile Pre for my laptop specifically so i can record sounds/ambience in the field. To record ambience efficiently, i invested in a stereo mic. Question is similar to the first asked, how do you connect a stereo mic to the Mobile Pre (via xlr)? The mic (a Rode SVM) has a male 1/8" out (because it is primarily used for video mic'ing). So my thought is use a female 1/8" to male 1/4" jack and connect that to a splitter. the only splitter i have found that seems to work with this idea is a female 1/4" that goes to dual male TRS and then attach two female 1/4" to male xlr adapters. Is there an easier way to do this? just so you know, the mic in on the Mobile Pre are TS not TRS. help please
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-14-2010 09:01 AM |
Mono input to record in stereo | larrylujack | Pro Tools M-Powered (Win) | 1 | 06-09-2008 06:49 AM |
Aux Track Input (Stereo/Mono) Question | paul Neathery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-17-2007 10:33 AM |
Mono Input to stereo track | Jiggyosa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-08-2005 12:21 PM |
stereo AS plugs w/ mono input | merz | Pro Tools TDM Systems (Mac) | 4 | 11-30-1999 01:55 AM |
