Old 06-06-2023, 07:04 AM
Armando Armando is offline
Default HDX PCI-e gen#??
What gen are the current HDX cards? Will they be compatible with the new Mac Pro or????
Armando
Old 06-06-2023, 11:27 AM
Default Re: HDX PCI-e gen#??
They are some old PCIe spec, 1 or 2, I can't remember, but PCIe is intended to be forward compatible so should work in principle. Apple even included the HDX card in their example cards shown at the announcement. But what will actually work, actually pass Digitest, actually do in situ firmware updates, actually work in max configs, actually be installable across double wide slots, etc. you need to either wait for Avid to officially support that or other users to test it carefully.
Old 06-06-2023, 03:20 PM
uptheoctave uptheoctave is offline
HDX is PCIE 1.1.
There is a GS post that quotes an email from Sonnet which says:
‘ The HDX card is PCIe 1.1 x4, links at PCIe 1,1 and does not come close to using the bandwidth of Thunderbolt 3, which is PCIe 3 x4.’
https://gearspace.com/board/music-co...interface.html
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 06-20-2023, 09:31 AM
innesireinar innesireinar is offline
Originally Posted by uptheoctave View Post
HDX is PCIE 1.1.
In the manual of the Sonnet Echo III there is written that if you want to seat an HDX card you should turn an internal switch to Gen2 otherwise the HDX will not work. But I've seen tons of pics of the mac pro 7.1 (2019) with HDX cards inside. And the mac pro 7.1 was PCIe gen3.
Really confusing...
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 06-20-2023, 10:09 AM
Really confusing...
No it is not. The PCIe 2 need is in Thunderbolt chassis only, thanks to bugs in the card design. What is supported is well documented. Stop worrying about PCIe specs if it seems confusing and just follow the directions for what is supported.
