Old 01-30-2018, 04:22 PM
abt abt is offline
Default VU meter set to -14dbfs
TLDR: Why is the default VU meter 0 set to -14ddfs and not -18dbfs?
I was playing around with different track meters. I normally use the digital meter but I like the idea of using the VU meter, it seems easier to read and makes more sense to be aiming for 0db.
I switch over to VU then all manor of confusion started. The more I played with it the more confused I got. I ended up running some test tones through it and found that -0db VU was -14dbfs.
Eventually I found the default meter setting in the preferences for the vu meter 0 is set to -14dbfs. I set it to -18dbfs and everything made sense.
So, why is the default -14dbfs? I always thought that 0vu should be -18dbfs? Should I be using -14dbfs?
Old 01-30-2018, 04:46 PM
studiostuff studiostuff is offline
Default Re: VU meter set to -14dbfs
-14 LUFS is sort of a recommended target level for audio going to You Tube and etc. That may have something to do with your question.
Old 01-30-2018, 06:07 PM
Sardi Sardi is offline
LUFS are not the same as dB RMS.
Interesting question. I wonder if the AVID interfaces are calibrated to -14. That might explain why.
Old 01-31-2018, 10:00 AM
We were talking about dBFS.
Why are the 882 converters calibrated to -14dbFS? HSLand Pro Tools TDM Systems (Mac) 1 01-05-2015 08:10 PM
why external vu meter/ plug-in vu meter differ? sjtae macOS 8 06-06-2012 05:50 PM
Inserts affecting send meter but not channel meter? Kbrinson85 Windows 1 05-01-2012 07:00 AM
PTHD8 cpu meter vs task manager cpu meter MEAT Pro Tools TDM Systems (Win) 5 01-02-2009 05:17 AM
where is the CPU meter MrMike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-24-2002 08:25 PM
