Old 04-30-2016, 04:00 PM
jonathan jetter jonathan jetter is offline
Default "Commit up to this insert" resets Slate Mix Rack
using "commit up to this insert" while having a VMR instance after the commit point (e.g. Melodyne on insert 1, VMR on insert 2, "commit up to Melodyne insert") will remove all VMR modules on both the committed track *AND* on the previous source track.
repeatable in multiple sessions, multiple track types, with various Slate VMR modules.
PT 12.5 HD Native, OS X Yosemite.
anyone else seeing this?
Old 04-30-2016, 04:04 PM
thanos4 thanos4 is offline
Default Re: "Commit up to this insert" resets Slate Mix Rack
That's an known issue and Slate's Team are aware of this
A fix will be come probably in the next build
Old 04-30-2016, 04:07 PM
However,a workaround i found until they fix this is:
When you want to commit a track which has VMR with "commit up to this insert"
just make inactive VMR and the committed track will have VMR with the right settings when you make it active
Old 04-30-2016, 04:13 PM
zion zion is offline
build
Most likely he will move on to a newer version like the up coming SSD 5 and drop all bugs fixes for older version or if he does fix it, it will take two years and there will be something new and better out by that time and you will just lose interest.
Old 04-30-2016, 04:42 PM
I am pretty sure they re close to the fix...
In latest build of VMR version 1.3.0.5 there is a fix for this issue but ONLY FOR 12.3
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
Digitest resets Omni I/O ins & outs to "None" rtcstudio Pro Tools TDM Systems (Mac) 1 10-02-2011 08:00 PM
"Setting Up Peripherals" Randomly Resets 003 Rack GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-06-2009 07:05 AM
Region TICK problem... not there in elastic mode but appears after "commit" ? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-04-2009 01:02 PM
compressor on the "insert" or "in-Line"? Dead River Studio Tips & Tricks 6 06-08-2002 04:12 AM
