Smux
Trying to connect 2 M-Audio Profire 2626s together to get 16 channels at 88/96. I've read its possible but cant seem to get Pro Tools 9 to see anything over 12 channels when running a session at 88 or 96. Using Windows 7 and PT9.
I have all 4 toslink cables connected. In the control panel mixer I can see its picking up channels 13-16 but in Pro Tools 9 it wont accept a signal after 12. I'm pretty sure i have everything set up correctly to the best of my knowledge. Any ideas? |
Re: Smux
here are some screen shots.
router tab: http://i53.tinypic.com/35byrsg.png settings tab: http://i53.tinypic.com/3492idv.png mixer tab: showing channel 16 as ADAT B in 4 http://i51.tinypic.com/ziwupz.png |
Re: Smux
Are you able to get all 16 at 44.1? I don't think PT has changed regarding the inability to recognize SMUX.
Re: Smux
Yes I can get 16 at 44 and 48. I knew pro tools le/m powered couldn't do it but I swore I read that pt9 changed that. Can anyone confirm this?
Re: Smux
SMUX uses twice the bandwidth. E.G. my Presonus FireStudio Light Pipe supports 44/48/88/96 and 32 channels. But.... It only supports 16 channels at the higher sample rates. Its a hardware limit.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: Smux
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
Re: Smux
Yes, normally i just record at 48 khz but some clients request higher sample rates. When using the two profires together at higher sample rates you should be able to send 4 channels through ADAT A and the other 4 channels through ADAT B, plus the 8 analog inputs. I can achieve this in the hardware no problem, its Pro Tools thats not seeing it. In the 2626's control panel, i can monitor all 16 inputs and hook up a mic to them to test, and i get the full 16 at 88 and 96 khz, but Pro Tools is only seeing the first twelve. 8 Analog, and 4 from ADAT A. It won't access ADAT B's last 4 channels.
Re: Smux
Flying blind here but have you gone into the IO tab in Setup and reset all of the inputs and Out puts and busses to thier defaults? yopu may need to do that to "See" the additional tracks.
Re: Smux
My first thought as well...
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Re: Smux
I reset the ins/outs and still nothing. Either way, they showed the inputs listed, it's just when arm recording a track with a channel set to 13-16 it acts as if there is no audio but I clearly see it coming through the profires dsp mixer. I guess pro tools just doesn't support this.
192 I/O e smux | lichimin | Pro Tools TDM Systems (Mac) | 8 | 09-26-2012 05:25 PM |
003 no SMUX - why?! | GreenHat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-02-2007 03:31 AM |
ADAT SMUX Format | iriegeorge | Pro Tools TDM Systems (Mac) | 0 | 11-01-2006 10:32 AM |
002 SMUX? | infamous plague | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-02-2006 10:03 AM |
ADAT SMUX at 88.2 and 96K | Bob Katz | Tips & Tricks | 4 | 12-20-2005 04:16 AM |
