Stereo Track with one input?
I was just wondering what you guys think the best way to do this would be. I am using Line 6 Gearbox plug-in for my guitar sounds. I generally keep the signal mono with a mono version of the plug, but every once in a while I like to use their stereo effects in their stereo version of the plugin and I would like to get a stereo output with just a single input going into the plug-in from the guitar. What do you think the best way to do this would be to get the least amount of latency. Thanks.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Re: Stereo Track with one input?
I haven't used it, but does it have a mono/stereo version? That would allow you to use a mono audio track, but inserting the plug-in would make the track's output stereo (2 meters, 2 pans, etc.). If not, you could either use an aux track and bus its output to a stereo audio track (probably a bit clunky since it would double the drive space and other resources required), or you could put something like a d-verb (mono/stereo) with it smix control set to 0% on the first insert. That would cause the inserts below it to become multichannel.
Hope that helps. |
Thank you. Yes, it does have a mono/stereo version. I didn't know that this meant it would allow a mono input and a stereo output on a track. Correct me if I am wrong, I assume you would start with a mono track and put the mono/stereo plug on the track and it will switch the output to stereo.
That's correct. It's a similar idea to using a mono aux track with a mono/stereo reverb. Then you can use a single bus to feed it but the reverb sound has a stereo image.
Instrument input stereo on the fast track? | eddiebrumley | Pro Tools M-Powered (Win) | 0 | 11-08-2011 08:05 AM |
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? | awhile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-17-2010 07:50 AM |
Aux Track Input (Stereo/Mono) Question | paul Neathery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-17-2007 10:33 AM |
Mono Input to stereo track | Jiggyosa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-08-2005 12:21 PM |
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 06-26-2002 03:21 PM |
