Re: \"external clock choice invalid. reverting to internal.\" HELP
Then that means the sampling rate is not the same.
Yes. I am using the default I/O settings. Like Digi said, try that.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I have always used the default settings, I've never had to change them with my current Digi setup. I tried changing the inputs (ADAT 1-2 I put to #1-2) but that didn't work at all either, so yes, they're all at default, basically they're all in a line (1 to 1, 2 to 2, etc). What else could it be?
When you select an input, should it say ADAT 1-8 after the analog inputs? Mine does, which seems logical, but a friend a with similar system (that works with lightpipe in) says other things like "888 in", even though he is using a 002.
Paul M. Grove bludatta.com |
The sample rate can only be 48K or 44.1K. I have tried both on the ADAT and in PT.
Any other ideas anyone?
Did you actually delete all the paths in IO setups for both input and output and default them? If not, try it - sometimes things *look* right, but actually aren't.
Also, how long are the optical cables between the 002 and the ADAT? Are you absolutely sure the connectors are 'fully in' - typically they should 'click' into the port. Silly questions, possibly, but we're getting to the end of possibilities, so we have to look at any little thing that could be a problem. |
#16
I will do that tonight, thanks for the tip. I had never changed the I/O so it SHOULD have always been the default, but obviously something is wrong so I'll delete and default.
The lightpipe cables are about 2 feet and I've swicthed them out a few times so I'm sure they're clicked in; plus I see the LED in the end. Are there any other hidden or not obvious software setups that it could be? I'm a pretty experienced PT user so I've been through all of it I know before I asked on this forum. It seems like it would have worked out of the box. If none of this works I'll have to suspect the ADAT I guess. I WAS experienced with them but it has been a few years!
HELP! The External Clock source is invalid, Reverting to Internal. | Jakepitts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-19-2011 01:27 PM |
Invalid clock source reverting to internal!! | route44 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-17-2006 11:13 PM |
"External Clock choice Invalid" | 685 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-24-2006 11:13 PM |
HELP-External Clock Invalid, Reverting To Internal | Clockwork12782 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-15-2004 11:43 AM |
external clock is invalid. reverting to internal.. | lowlight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-12-2004 11:58 AM |
