Old 02-11-2007, 06:24 AM
scidef scidef is offline
Default Please HELP!!! need to move my PT plug ins folder!
Hello
Reallly need some help!
I have just done a really complicated reformat of my CPU and have set up many partitions and need to move my plug ins folder or set up an additonal folder to scan for my RTAS plug ins.
It installed (without letting me choose) to C:\program files\commmon files\digidesign and I need to either move to D: Drive or set up another folder to scan for plug ins on start up.
I cant have my plug ins on my C Drive and will need to resize all my partitions and will generate a lot of problems if I cant move.
I cant find an option anywhere in the docs or software to change this. Its so easy to do on every other program I use. I have also tried old school methods like creating alias shortcuts like in Logic!!!
PLLLLEAASE HELP!
Hopefully I am just being thick!
Steve
Old 02-11-2007, 07:54 AM
spkguitar's Avatar
Default Re: Please HELP!!! need to move my PT plug ins fol
What you are attempting is definitely NOT recommended. It is recommended that Pro Tools, and all of it's plugins and peripheral programs be installed to the system drive.
Doing otherwise will (not can, will) cause Pro Tools not to function properly.
I don't really understand why you would do this or want to do this. There is no real advantage to doing so. I could understand installing the sample libraries of some plugins to another drive (I do that myself), but there is no advantage at all to installing the plugins themselves elsewhere.
Old 02-11-2007, 08:29 AM
Thanks for your advice.
I am tring to install only windows on one partition and all apps and plug ins on a different partition to increase stability. I have only a 10GB partition for system and intend on installing many plug ins I also test many out demos etc. and uninstall this has caused me probs in the past.
Would this advice also extend to the VST to RTAS adapter?
Thanks again.
S
Old 02-11-2007, 09:07 AM
JMS40 JMS40 is offline
Pro Tools, all plugs and the VST adapter should be installed in their default locations on the C: system drive.
As spkguitar has said, sample libraries used by plugs can be installed on a separate drive to increase performance.
And of course, your PT session files should be located on a separate drive. But the applications need to be installed to the system drive.
For what it's worth, separate partitions of the same drive do not increase performance. It is even possible it will increase the workload of the single drive under some circumstances.
In other words, a partitioned single drive does not have the performance advantage of actual separate drives.
Plug-ins problem - Move Unauthorized Plug-ins [SOLVED] HBHH macOS 4 10-03-2013 04:26 PM
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. We live forever Virtual Instruments 55 09-17-2012 06:02 PM
Plug-Ins Alias folder points to wrong folder??? nod25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-26-2009 03:43 PM
plug-ins folder / not finding plug-in BFD IVcrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-27-2005 06:25 AM
Putting TDM plug-Ins in LE Plug-In Folder? flymax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-07-2001 01:56 PM
