Old 09-17-2006, 08:51 PM
route44 route44 is offline
Default Invalid clock source reverting to internal!!
Hi everybody...
I am using a Dual 2.5 G5 with 2.5GB of ram, a Digi002r and an ADAT XT 20.
I cannot seem to figure out why the clock source wont let me set the adat up to get those extra 8 tracks.
It doesnt even show up in the peripherals, if that matters.
I have been using PTLE 5.1.1 on a G4 with the Digi 001 and the very same ADAT and have had no problems whatsover.
What am I missing here? I have dbl checked the Lightpipes are in tight and properly set in-out and out-in.
This must be something rudimentary in the newer versions?
Old 09-17-2006, 09:31 PM
fire2k2 fire2k2 is offline
Default Re: Invalid clock source reverting to internal!!
That happens with my G5 as well.* Usually a restart of my computer and my A/D will fix it.
Old 09-17-2006, 10:11 PM
Thanks for the rapid response but sadly this did not fix the issue.
I should clarify the correct error message I am receiving when setting clouck source to ADAT is:
"The External Clock Choice is Invalid. Resetting to Internal."
So I am basically dead in the water for receiving the 8 extra outs from my ADAT via the
Soundcraft Mixer's TRS analog direct outs feeding into
the ADAT via 56pin Elco Snake,
and leaving ADAT XT20 via
the lightpipe out--->into Digi002 Rack optical in.
Still perplexed, if anyone knows the secret handshake for this, it would be greatly appreciated.
Thanks in advance!
Old 09-17-2006, 11:01 PM
BFrederick BFrederick is offline
Are you certain in your PT hardware preferences that your optical in is set to ADAT as opposed to SPDIF?
BRENT FREDERICK
Musical Director, Arranger, Pianist
PT10, MOTU Audio Express, 10.7.2
http://www.BrentFrederickMusic.com
Old 09-17-2006, 11:13 PM
How would I set that? (PT Prefs optical in)
I am thinking it already says on the top line: RCA=SPDIF, Optical=ADAT
Thanks for replying, any help is very much appreciated.
Word clock setting is invalid ...pt reverting it ... jeam25 Windows 5 11-04-2011 01:24 PM
HELP! The External Clock source is invalid, Reverting to Internal. Jakepitts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-19-2011 01:27 PM
"external clock choice invalid. reverting to internal." HELP raccoon3030 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 05-02-2007 11:30 AM
HELP-External Clock Invalid, Reverting To Internal Clockwork12782 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-15-2004 11:43 AM
external clock is invalid. reverting to internal.. lowlight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2004 11:58 AM
