DigiDelivery 2.1 versus Network Home Directories
Under OS X 10.4.6, DigiDelivery 2.1 build 393 refuses to launch if the current account has a network home directory.
If I mv ~/Library to ~/Library.old and then ln -s /Users/Shared ~/Library (symlinking ~/Library to a folder on the local drive), DigiDesign launches just fine. Since our users have network accounts, this is a showstopper. -- Greg Neagle Sr Systems Engineer Walt Disney Feature Animation |
Re: DigiDelivery 2.1 versus Network Home Directories
Thanks for the heads-up Greg. We're looking ito it now. Did this work any better under earlier versions of OSX?
I don't know how it behaved under older versions of OS X, but would be happy to test if you'd like.
I just tested under Mac OS X 10.3.9 and replicated the same behavior.
--- Greg Neagle Sr Systems Engineer Walt Disney Feature Animation |
We're looking into the cause - can you please do the following?
1. Create a folder named "Logs" in the same folder as your DigiDelivery client 2. Try sending a delivery 3. Open the Logs folder and email the text file to [email protected] with a brief note explaining this came from an OSX network drive. Interestingly, the same day you posted this another email crossed my desk stating the Pro Tools has the same issue... Thanks, Gordon |
I've created the "Logs" folder, but nothing ever gets written there. Nothing is written to /var/log/system.log, nor to the console.log, nor to CrashReporter. You double-click on the app, you see the zooming animation, then nothing. Same app with a local account launches just fine.
-Greg |
PT 11 and network home directories | [email protected] | macOS | 6 | 03-17-2014 10:31 AM |
Sharing sessions via home network | Jamesr10 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-07-2009 02:46 PM |
Workspace keeps adding artificial home directories | buddhajuke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-25-2008 10:49 AM |
Partial Fix for Remote Home Directories | Rob J. Caskey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-15-2006 06:57 PM |
Setting up Digidelivery on my network | uno1234 | Aspera DigiDelivery | 3 | 12-12-2005 02:41 PM |
