Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-24-2024, 03:52 PM
audiogamble audiogamble is online now
Default Avid Control "NoName" folder tracks
I've been experiencing this for a while now. On occasion, in larger mix sessions, when I make a folder it will display as "NoName" on the Avid Control app. The folder name will show up fine on my linked Avid S1 . Closing and opening the session, or closing and opening avid control fixes the issue.
I am running a 5th generation iPad with OS 16.7.4 with the latest avid control app (2023.11). Eucon is hosted on an M1 Max 16" MacBook Pro on Ventura 13.6.5 running in native silicon mode.
The iPad is connected via ethernet to a router that is dedicated to eucontrol (camera kit + usb to ethernet adapter). WIFI is off and it does not connect to the internet.
I kept some logs from the most recent incident if Eddie or someone else in a position to fix it sees the post.
Thanks
Old 03-25-2024, 09:24 AM
EddieJones's Avatar
Default Re: Avid Control "NoName" folder tracks
We'll keep an eye open for it...
Old 03-25-2024, 12:42 PM
Thanks Eddie. Appreciate it.
Seems to be tied to heavy sessions on the host computer. In a session with just tracks playing back with no processing I don't often see it. If I have a mix almost finalized & lots of plugins / routing already going, I'll see this happen fairly often when I do a big session-wide operation like making a track folder.
Avid Control Frequently Displays "No Name" for folder tracks audiogamble Avid S1, S3, Dock and Control App 2 11-09-2023 05:12 PM
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 03:43 PM
"Avid" folder is missing OutbackStudios Pro Tools 11 1 10-01-2015 01:27 PM
Task Manager , "Obtain folder contents" , "Expanding Tree" ??? joachim Tips & Tricks 0 06-15-2015 11:10 AM
"Digidesign" Folder not shown in "Application Support" jollyboss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-01-2012 02:12 AM
