Old 05-13-2006, 04:48 PM
sodium glow sodium glow is offline
Default Copy fader level/pan to send?
Is there a command to copy the fader and pan settings of all tracks to a send on all tracks? Like for setting up a que mix.
Example:
24 tracks
setup control rool mix out interface 1-2
copy all pan/levels so send 1-2 is now a copy of control room mix
take send 1-2 (pre fade) out interace 3-4 to que system for band mix
Thanks
Old 05-13-2006, 04:53 PM
Stig Eliassen's Avatar
Default Re: Copy fader level/pan to send?
Yes.
Select the tracks, press Command-Option-H.
Old 05-14-2006, 04:39 AM
Thanks!
Old 05-14-2006, 12:46 PM
Danny Caccavo Danny Caccavo is offline
Actually, in the upcoming Pro Tools 7.2 release, we'll be adding an "FMP" button to the sends (Follow Main Pain). Should help with the cue mixes, as well as maintaining pans when automating certain routing assignments. Plus a pref to allow new sends to default that way.
Danny Caccavo
Product Manager
Digidesign
Old 05-14-2006, 12:59 PM
filmixer filmixer is offline
>we'll be adding an "FMP" button to the sends *(Follow Main Pain)*. Should help with the cue mixes, as well as maintaining pans when automating certain routing assignments.<
Well, I hope it's not painful. Seems like "FMP" will be nice for setting up automated multichannel buss reassignment as well by using some of the sends for Stem routing.
Mark Ettel C.A.S.
Old 05-17-2006, 02:06 AM
TommyT TommyT is offline
Hey does this work in PT 7 after selecting the track & pressing command option H i do get the dialog box but after hitting ok nothing happens and nothing gets assigned... the dialog box goes away but that's it... is it broken in PT7 cs7 or am i missing something ?
PT 7cs7 Quad HD
Cheers Tom..
Old 04-19-2010, 07:35 AM
barp barp is offline
Question Re: Copy fader level/pan to send?
After all ... there is the function "copy to send" in Pro Tools M-Powered?
Old 04-19-2010, 07:37 AM
Drew Mazurek's Avatar
HD only.
www.drewmazurek.com
Old 09-27-2017, 12:55 PM
ian Bourgal ian Bourgal is offline
Does anyone know when this function (Command-Option-H) was introduced?
Was this available in PTLE 7.3 ?
Old 09-27-2017, 03:13 PM
HD-only
Send level suddenly dup'ed down to the fader? Stig Eliassen ICON & C|24 4 09-20-2009 09:40 AM
copy a send (w/send level intact) from 1 to 30 audio tracks? MixerGuy Pro Tools TDM Systems (Mac) 3 12-30-2007 03:20 PM
7.3.1 Send level meter just mirrors track level bashville Pro Tools TDM Systems (Mac) 11 01-16-2007 08:19 PM
channel level mirrored in send level meter daveh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2001 01:32 AM
Q: copy record level to playback level? regis Pro Tools TDM Systems (Mac) 1 11-04-2000 06:36 PM
