Old 02-05-2020, 08:19 AM
EddieJones's Avatar
Default Re: Artist Mix wont Connect to Eucontrol
Sorry, I've been meaning to reply.
When you say this:
- I did this:
IP address: 10.0.0.2
Subnet Mask: 255.255.0.0
What do you mean and why are you doing that ?
Old 02-05-2020, 04:14 PM
ktyitye ktyitye is offline
Originally Posted by EddieJones View Post
To see the IP address on the Mix, power it off then while holding down the <PAGE> keys simultaneously, press and release the POWER switch. Continue to hold the <PAGE> keys down until the display lights. You should now see the IP address.
On Windows 10 type cmd into the search bar bottom left and press enter. In the Black window that opens type ipconfig and enter.
I found the IP address on the Mix, but the IP on my windows 10 is different. Should I make them both the same? If so, how do I do that?
Old 02-05-2020, 04:35 PM
EddieJones's Avatar
If you found the IP on the Mix that must mean it was set to a static address. You need both the Mix and the computer set to DHCP (these are the defaults so not sure how they get changed)
So, go back to the Mix and set it to DHCP (where you saw the IP address)
In windows find the Networking Control Panel and the adapter you are using for EUCON in its properties make sure it looks like this image
Old 02-06-2020, 10:41 AM
Success!! Its working!!!!!!!! So excited, thanks for your help!
Old 02-06-2020, 10:48 AM
EddieJones's Avatar
Yay! Glad to hear.
  #16
Old 03-19-2020, 03:30 PM
psalcal psalcal is offline
May I add to this thread?
I did the reboot with command thing and I see the DHCP thing. But I don't see how to "proceed" beyond that. What key do I hit to "accept" the DHCP?
Also I'm noticing the other end of my cable at my router doesn't light up... meaning, it doesn't appear to have a connection. I've tried a couple of cables to no avail... seems like it should light up there?
  #17
Old 03-19-2020, 03:35 PM
EddieJones's Avatar
Did you try a different port on the router/switch ?
  #18
Old 03-19-2020, 05:17 PM
Yes that's the first thing I tried. Also just swapped cables again with one which is for sure working with my wifi hotspot.
Can you please verify how I get beyond the IP address? It's showing "use DHCP yes" in the upper left, but how do I get it to move to the next screen? Hitting other keys seems to bring up static IP address-related options.
OR... maybe it will move on from that display automatically once it gets an IP address?
  #19
Old 03-19-2020, 06:04 PM
EddieJones's Avatar
Did you press the page left and right keys together like the guide says ?
  #20
Old 03-19-2020, 09:47 PM
EDIT.. missed that part in the manual. So I hit page/page again, and now I'm back to the "AVID" across all eight channels.
BUT... no light shows up on my network switch. Tried a different device on the end of the same cable, and light comes on at the switch.
Is it possible I have a bad Artist Mix now? It has been sitting unused in an install. I'm trying to revive it to put it in a different install, so any advice is appreciated. Thank you.
Download Artist Mix Firmware from Eucontrol 18.3? sjgam Artist Series 2 10-11-2018 04:56 PM
Eucontrol 3.6.0 Firmware 1.5.4 (Artist Mix) Not Working Oady Artist Series 10 05-27-2017 05:19 AM
Artist Mix not appearing in EuControl JakeHa Artist Series 0 07-22-2016 04:39 PM
EuControl v3.2.2 for Artist and S3 Now Available Avid Technical Alerts 0 04-03-2015 07:23 PM
Artist series, Eucontrol, Support: Sorry, I don't get it. OTARI Artist Series 15 08-09-2013 08:07 AM
