Pro Tools constantly crashing while saving
Hello!
I have been having this problem for a long time but now it became completely unbearable. Pro Tools is constantly crashing while trying to save the session. I disabled auto-save so I could have at least a couple of minutes of peace. Crashing occurs randomly. Sometimes I can save 3-4 times, then it crashes. Sometimes it crashes about 10 times in a row even if I open the session and try to save it immediately (in both cases, with Cmd+S and "Save as..."). Crashes occur while using either digital or analog onboard output. What has already been done: - Memory check by Apple Hardware test (as some members mentioned "KERN_INVALID_ADDRESS" as a possible memory issue) - no problems found - Reimporting session info into a new session - Trying to copy the project to the internal SSD - Changing on how many cores should PT run - Making sure owners are ignored for the external drive - Trashing preferences, DAE folder, volumes, plist, databases etc. - Turn off Bluetooth and Wi-Fi Here's an average crash report: Process: Pro Tools [246] Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 10.3.7.296 (10.3.7f296) Build Info: Unknown-10370296~296 Code Type: X86 (Native) Parent Process: launchd [144] User ID: 501 Date/Time: 2013-12-10 23:40:17.643 +0100 OS Version: Mac OS X 10.8.5 (12F45) Report Version: 10 Interval Since Last Report: 28883 sec Crashes Since Last Report: 10 Per-App Interval Since Last Report: 10787 sec Per-App Crashes Since Last Report: 10 Anonymous UUID: 5DA833C4-7706-261E-FC1C-20FFCD46CDAC Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x000000007c010052 VM Regions Near 0x7c010052: MALLOC_SMALL 000000003c000000-000000003d000000 [ 16.0M] rw-/rwx SM=PRV --> __TEXT 000000008e2fa000-000000008ec4a000 [ 9536K] r-x/rwx SM=COW /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libc++abi.dylib 0x922e4d5c __dynamic_cast + 36 1 com.digidesign.framework.ProTools 0x0e457493 LaunchProTools + 70179 2 com.digidesign.framework.ProTools 0x0d51a9b7 MFortressHWBPEntryPoint_exit_mfort6317_ + 11658029 3 com.digidesign.framework.ProTools 0x0d51b057 MFortressHWBPEntryPoint_exit_mfort6317_ + 11659725 4 com.digidesign.framework.ProTools 0x0d9e2a81 MFortressHWBPEntryPoint_exit_mfort6317_ + 16671735 5 com.digidesign.framework.ProTools 0x0d0473aa MFortressHWBPEntryPoint_exit_mfort6317_ + 6597920 6 com.digidesign.framework.ProTools 0x0cd7ff30 MFortressHWBPEntryPoint_exit_mfort6317_ + 3684518 7 com.digidesign.framework.ProTools 0x0d9ebe7d MFortressHWBPEntryPoint_exit_mfort6317_ + 16709619 8 com.digidesign.framework.DFW 0x005a8557 TFileBasedDocument::SaveDocument(long) + 119 9 com.digidesign.framework.ProTools 0x0d97c243 MFortressHWBPEntryPoint_exit_mfort6317_ + 16251833 10 com.digidesign.framework.DFW 0x0059f12e TSaveDocCommand::DoIt() + 30 11 com.digidesign.framework.DFW 0x005988fb TCommandHandler::PerformCommand(TCommand*) + 187 12 com.digidesign.framework.DFW 0x0059924f TCommand::Process() + 31 13 com.digidesign.framework.DFW 0x0058ecfa TApplication::ProcessEvent(TEvent*) + 26 14 com.digidesign.framework.DFW 0x0058f610 TApplication::WakeUp() + 64 15 com.digidesign.framework.DFW 0x006f555b TApplication::CreateNewOSApplication(void*, void*, void*) + 667 16 com.apple.HIToolbox 0x91ff39bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36 17 com.apple.HIToolbox 0x91e7b394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343 18 com.apple.HIToolbox 0x91e7a780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430 19 com.apple.HIToolbox 0x91e7a5ca SendEventToEventTargetWithOptions + 94 20 com.apple.HIToolbox 0x91eae98e ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 3108 21 com.apple.HIToolbox 0x91e7b83f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2538 22 com.apple.HIToolbox 0x91e7a780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430 23 com.apple.HIToolbox 0x91e8e655 SendEventToEventTarget + 88 24 com.apple.HIToolbox 0x91ff30b7 ToolboxEventDispatcher + 82 25 com.apple.HIToolbox 0x91ff2f79 RunApplicationEventLoop + 240 26 com.digidesign.framework.DFW 0x006fea9b DFW_EventLoop::RunApplicationEventLoop() + 11 27 com.digidesign.framework.DFW 0x0058edcd TApplication::Run() + 45 28 com.digidesign.framework.ProTools 0x0e4452d1 MFortressHWBPEntryPoint_exit_mfort6317_ + 27561031 29 com.digidesign.framework.ProTools 0x0e4467f4 LaunchProTools + 1412 30 com.digidesign.ProTools 0x0000f277 0x1000 + 57975 31 com.digidesign.ProTools 0x0001037a 0x1000 + 62330 32 com.digidesign.ProTools 0x0000effd 0x1000 + 57341 ... Thread 0 crashed with X86 Thread State (32-bit): eax: 0x7c010052 ebx: 0x0e456df1 ecx: 0x0f1f8294 edx: 0x713a4e01 edi: 0xbfffdf7c esi: 0x24e9d400 ebp: 0xbfffdb48 esp: 0xbfffdb00 ss: 0x00000023 efl: 0x00010202 eip: 0x922e4d5c cs: 0x0000001b ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f cr2: 0x7c010052 Logical CPU: 6 ... External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 15 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 198 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=366.2M resident=259.6M(71%) swapped_out_or_unallocated=106.6M(29%) Writable regions: Total=593.1M written=213.8M(36%) resident=393.5M(66%) swapped_out=0K(0%) unallocated=199.6M(34%) REGION TYPE VIRTUAL =========== ======= (null) (reserved) 16.2M reserved VM address space (unallocated) ATS (font support) 32.8M CG backing stores 23.6M CG image 104K CG shared images 160K CoreAnimation 5476K CoreServices 1568K IOKit 45.3M IOKit (reserved) 4K reserved VM address space (unallocated) MALLOC 366.9M MALLOC guard page 48K MALLOC_LARGE (reserved) 20.0M reserved VM address space (unallocated) Mach message 20K Memory tag=240 4K Memory tag=242 12K Memory tag=249 156K Memory tag=35 2440K OpenCL 28K OpenGL GLSL 1552K OpenGL GLSL (reserved) 128K reserved VM address space (unallocated) Stack 94.5M VM_ALLOCATE 54.0M __DATA 47.3M __DATA/__OBJC 240K __IMAGE 528K __IMPORT 148K __LINKEDIT 75.5M __MFRT 8K __OBJC 2800K __OBJC/__DATA 44K __PAGEZERO 4K __PDSIG 300K __POVERD 4K __POVERDDATA 20K __POVERT 4K __POVERTEXT 20K __TEXT 290.7M __UNICODE 544K mapped file 225.4M shared memory 7244K =========== ======= TOTAL 1.3G TOTAL, minus reserved VM space 1.2G Model: MacBookPro10,1, BootROM MBP101.00EE.B03, 4 processors, Intel Core i7, 2.4 GHz, 16 GB, SMC 2.3f36 Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 512 MB Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020 Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020 AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.100.17) Bluetooth: Version 4.1.7f2 12718, 3 service, 13 devices, 3 incoming serial ports Network Service: Wi-Fi, AirPort, en0 PCI Card: Universal Audio UAD-2 SOLO/Laptop, sppci_othermultimedia, Thunderbolt@10,0,0 Serial ATA Device: APPLE SSD SD512E, 500,28 GB USB Device: My Passport 0730, 0x1058 (Western Digital Technologies, Inc.), 0x0730, 0x15200000 / 1 USB Device: hub_device, 0x8087 (Intel Corporation), 0x0024, 0x1a100000 / 2 USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8510, 0x1a110000 / 3 USB Device: hub_device, 0x8087 (Intel Corporation), 0x0024, 0x1d100000 / 2 USB Device: USB 2.0 Hub, 0x1a40 (TERMINUS TECHNOLOGY INC.), 0x0101, 0x1d110000 / 6 USB Device: MIDI Timepiece AV, 0x07fd, 0x0001, 0x1d111000 / 10 USB Device: iLok, 0x088e, 0x5036, 0x1d114000 / 9 USB Device: USB Receiver, 0x046d (Logitech Inc.), 0xc52b, 0x1d112000 / 7 USB Device: hub_device, 0x0424 (SMSC), 0x2512, 0x1d180000 / 3 USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0263, 0x1d182000 / 5 USB Device: BRCM20702 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1d181000 / 4 USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8286, 0x1d181300 / 8 Any help and advice will be very much appreciated.
MacBook Pro Retina 15 Early 2013, Core i7 2,4 GHz, 16 GB DDR3, 500 GB SSD (System) + WD My Passport Essential HDD USB 3.0 (Recording/Playback), NVIDIA GeForce GT 650M 1024, 2880x1800 OS X 10.8.5 Pro Tools 10.3.7 UAD-2 Solo ExpressCard via Echo/Thunderbolt, 7.2.0 Sonnox Elite AAX, Lexicon PCM, Waves 9 Silver + Vocal AAX Last edited by 1176LN; 12-11-2013 at 08:39 AM. |
Re: Pro Tools constantly crashing while saving
Hoping AVID will take a look at this, because it's a common problem in 10 AND 11. If you do a CTRL>S (typically a good idea!) while it's rendering ANYTHING, it gives a "can't save while rendering tracks" error, then an assertion error, then a handful of access violations, and corrupts the session. Workaround: Session backups OFF (crap!) and count to 5 before you do a control>S. And mine's on Windows. The fact that your MAC does it too REALLY points to a bug, not a system configuration issue.
The ONLY reason I paid ****load of money and switched to Mac was a hope that at least this way I can work with Pro Tools without problems. I was wrong.
MacBook Pro Retina 15 Early 2013, Core i7 2,4 GHz, 16 GB DDR3, 500 GB SSD (System) + WD My Passport Essential HDD USB 3.0 (Recording/Playback), NVIDIA GeForce GT 650M 1024, 2880x1800 OS X 10.8.5 Pro Tools 10.3.7 UAD-2 Solo ExpressCard via Echo/Thunderbolt, 7.2.0 Sonnox Elite AAX, Lexicon PCM, Waves 9 Silver + Vocal AAX |
I would see if you can get some other RAM to put into the computer and see if you still have the problem. I had a very similar problem and I put my old RAM in the computer and problem gone.
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Unfortunately, it's not possible to put any other RAM into my computer.
Hi
Have you tried to start a session with your main OS drive only as that WD My passport is not what one would recommend even though it's USB3. Those drives are most certain 5400 rpm or less and they could have some form of "green" power saving mgnt so i would either get something that works well with PT and make a backup of that drive and then maybe use it as a back-up at most. Not have anything to do with recording at all. Try disconnecting that harddrive and start a new session OR import/move one of your sessions to the SSD drive and try PT with WD out of the picture, What happens then? As you are using that for recording means it is used for saving and reading to and from so that drive might very well be a part of your issues here. Also there is a host of stuff for optimization and trouble shooting to do aswell here http://duc.avid.com/showthread.php?t=300050 and make sure you do everything and everything before doing anything drastic. No bluetooth on, no network on, trashing preferences, dae folder, volumes, plist, databases etc. Very important to do as that is almost always some sort of culprit even though you think those small things doesn't matter, do them ALL Best Wishes Christopher
Can you post some more crash reports. Especially any ones that may show different details in the crashed thread stack trace (in this case the sequence of calls shown in stack 0).
I hope you guys complaining about a bug have fully removed all third party plugins (AAX and RTAS in the case of Pro Tools 10) and if that did not work, leave them uninstalled and do a uninstall of Pro Tools 10 and a reinstall. It is still possible for this to be plugin related bug.
Process: Pro Tools [822] Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 10.3.7.296 (10.3.7f296) Build Info: Unknown-10370296~296 Code Type: X86 (Native) Parent Process: launchd [142] User ID: 501 Date/Time: 2013-12-11 06:23:48.903 +0100 OS Version: Mac OS X 10.8.5 (12F45) Report Version: 10 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x00000000fffffffc VM Regions Near 0xfffffffc: --> shared memory 00000000ffffd000-00000000ffffe000 [ 4K] r-x/r-x SM=SHM Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libstdc++.6.dylib 0x9a250bfb std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string() + 33 1 com.sonnox.aaxeqplugin 0x20b505a0 0x20a9c000 + 738720 2 com.sonnox.aaxeqplugin 0x20b4ed60 0x20a9c000 + 732512 3 com.sonnox.aaxeqplugin 0x20aa7fc3 0x20a9c000 + 49091 4 com.digidesign.framework.DAE 0x0f6caa8d FicHostPlugInRunnerInit + 219581 5 com.digidesign.framework.DAE 0x0f6645f3 FicGetPlugInChunk + 51 6 com.digidesign.framework.ProTools 0x0d0172bd MFortressHWBPEntryPoint_exit_mfort6317_ + 8326195 7 com.digidesign.framework.ProTools 0x0cffefe8 MFortressHWBPEntryPoint_exit_mfort6317_ + 8227166 8 com.digidesign.framework.ProTools 0x0d021190 MFortressHWBPEntryPoint_exit_mfort6317_ + 8366854 9 com.digidesign.framework.ProTools 0x0ce405cf MFortressHWBPEntryPoint_exit_mfort6317_ + 6397765 10 com.digidesign.framework.ProTools 0x0ce5fb5e MFortressHWBPEntryPoint_exit_mfort6317_ + 6526164 11 com.digidesign.framework.ProTools 0x0ce81a93 MFortressHWBPEntryPoint_exit_mfort6317_ + 6665225 12 com.digidesign.framework.ProTools 0x0ce78623 MFortressHWBPEntryPoint_exit_mfort6317_ + 6627225 13 com.digidesign.framework.ProTools 0x0cf241a0 MFortressHWBPEntryPoint_exit_mfort6317_ + 7330582 14 com.digidesign.framework.ProTools 0x0cf1bf4e MFortressHWBPEntryPoint_exit_mfort6317_ + 7297220 15 com.digidesign.framework.ProTools 0x0d81155d MFortressHWBPEntryPoint_exit_mfort6317_ + 16690899 16 com.digidesign.framework.ProTools 0x0d815a2e MFortressHWBPEntryPoint_exit_mfort6317_ + 16708516 17 com.digidesign.framework.DFW 0x005a8557 TFileBasedDocument::SaveDocument(long) + 119 18 com.digidesign.framework.ProTools 0x0d7a6243 MFortressHWBPEntryPoint_exit_mfort6317_ + 16251833 19 com.digidesign.framework.DFW 0x0059f12e TSaveDocCommand:oIt() + 30 20 com.digidesign.framework.DFW 0x005988fb TCommandHandler::PerformCommand(TCommand*) + 187 21 com.digidesign.framework.DFW 0x0059924f TCommand::Process() + 31 22 com.digidesign.framework.DFW 0x0058ecfa TApplication::ProcessEvent(TEvent*) + 26 23 com.digidesign.framework.DFW 0x0058f610 TApplication::WakeUp() + 64 24 com.digidesign.framework.DFW 0x006f555b TApplication::CreateNewOSApplication(void*, void*, void*) + 667 25 com.apple.HIToolbox 0x91ff39bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36 26 com.apple.HIToolbox 0x91e7b394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343 27 com.apple.HIToolbox 0x91e7a780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430 28 com.apple.HIToolbox 0x91e7a5ca SendEventToEventTargetWithOptions + 94 29 com.apple.HIToolbox 0x91eae98e ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 3108 30 com.apple.HIToolbox 0x91e7b83f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2538 31 com.apple.HIToolbox 0x91e7a780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430 32 com.apple.HIToolbox 0x91e8e655 SendEventToEventTarget + 88 33 com.apple.HIToolbox 0x91ff30b7 ToolboxEventDispatcher + 82 34 com.apple.HIToolbox 0x91ff2f79 RunApplicationEventLoop + 240 35 com.digidesign.framework.DFW 0x006fea9b DFW_EventLoop::RunApplicationEventLoop() + 11 36 com.digidesign.framework.DFW 0x0058edcd TApplication::Run() + 45 37 com.digidesign.framework.ProTools 0x0e26f2d1 MFortressHWBPEntryPoint_exit_mfort6317_ + 27561031 38 com.digidesign.framework.ProTools 0x0e2707f4 LaunchProTools + 1412 39 com.digidesign.ProTools 0x0000f277 0x1000 + 57975 40 com.digidesign.ProTools 0x0001037a 0x1000 + 62330 41 com.digidesign.ProTools 0x0000effd 0x1000 + 57341 ... Thread 0 crashed with X86 Thread State (32-bit): eax: 0xfffffff4 ebx: 0x034c8a1c ecx: 0x00000000 edx: 0xffffffff edi: 0x20d519f8 esi: 0x034c9090 ebp: 0xbfffbe48 esp: 0xbfffbe40 ss: 0x00000023 efl: 0x00010206 eip: 0x9a250bfb cs: 0x0000001b ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f cr2: 0xfffffffc Logical CPU: 0 ... External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 15 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 980 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=366.6M resident=270.8M(74%) swapped_out_or_unallocated=95.8M(26%) Writable regions: Total=589.9M written=247.6M(42%) resident=416.8M(71%) swapped_out=0K(0%) unallocated=173.2M(29%) REGION TYPE VIRTUAL =========== ======= (null) (reserved) 16.2M reserved VM address space (unallocated) ATS (font support) 32.8M CG backing stores 24.9M CG image 116K CG raster data 116K CG shared images 192K CoreAnimation 5284K CoreImage 4K CoreServices 1568K IOKit 49.0M IOKit (reserved) 4K reserved VM address space (unallocated) MALLOC 366.5M MALLOC guard page 48K MALLOC_LARGE (reserved) 20.4M reserved VM address space (unallocated) Mach message 20K Memory tag=240 4K Memory tag=242 12K Memory tag=243 8K Memory tag=249 156K Memory tag=35 2420K OpenCL 28K OpenGL GLSL 1552K OpenGL GLSL (reserved) 128K reserved VM address space (unallocated) Stack 94.5M VM_ALLOCATE 45.8M __DATA 47.3M __DATA/__OBJC 240K __IMAGE 528K __IMPORT 148K __LINKEDIT 75.5M __MFRT 8K __OBJC 2788K __OBJC/__DATA 56K __PAGEZERO 4K __PDSIG 300K __POVERD 4K __POVERDDATA 20K __POVERT 4K __POVERTEXT 20K __TEXT 291.1M __UNICODE 544K mapped file 231.3M shared memory 24.1M =========== ======= TOTAL 1.3G TOTAL, minus reserved VM space 1.3G
PT 10.3.7 crashing CONSTANTLY! | LSD-Studio | macOS | 6 | 11-30-2013 11:56 AM |
Pro Tools 10 constantly crashing | Scott Swallow | Pro Tools 10 | 5 | 10-15-2012 09:29 AM |
Pro Tools 8 constantly crashing with no errors | theunder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-26-2011 01:18 PM |
Help! Pro Tools is constantly crashing | whirlwind | Pro Tools TDM Systems (Mac) | 3 | 08-04-2005 10:12 PM |
Crashing constantly in 6.9.....Help! | Sty1es | Pro Tools TDM Systems (Mac) | 4 | 06-08-2005 09:47 AM |
