#21
Re: will Protools HD ever get ARA or an equivalent Edit System
There are other platforms and vendors that have announced ARA 2 support, but I have not heard anything like that about Avid / Pro Tools. It may be a long time coming (if ever) because integrating with AAX is a whole different ballgame than integrating with VST, and the integration requires some reworking of editing on the host. I believe (could be wrong) S1, Reaper, and Logic are all on board with ARA 2 support currently. I know Reaper will be releasing it almost simultaneously with the Melodyne ARA2 release, and S1 might be doing the same.
#22
Interesting...
You say with aax it is a different story, than VST... But Logic will get Ara2...and Logic does not support vst... So is AU a different story, than VST?... |
#23
The longer the speech, the less thought
No long workarounds ARA integration in Pro Tools. + 100 |
#24
Workaround: a word that means "my DAW doesn't do that".
#25
Each plugin spec is different. I know little about AU, but if Logic is implementing ARA 2 through AU then they have it figured out.
#26
We have just posted a story with a video demonstrating the power of ARA2 with Revoice Pro in Studio One.
We need this in Pro Tools asap. This would revolutionise the workflow with applications like iZotope RX and Synchro Arts Revoice Pro, in fact, any tool that currently needs a round trip. Imagine changes made in RX being immediately reflected on the timeline in Pro Tools. As we say on Production Expert "it's not often we use this phrase but ARA2 is a gamechanger". |
#27
Absolutely Mike. ARA2 from what I have seen thus far, is a total game changer.
I can imagine working away in RX on a section of audio and using the S3 and Dock to run the Pro Tools session, whilst hearing your RX edits in complete context (including the track plugin chain) of the edit/mix. Much better than having to setup RX monitor etc and as you say, doing the back & forth round trip.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
#28
Vote it up on IdeaScale
https://protools.ideascale.com/a/dtd...a-tab-comments and while you're there, maybe.... https://protools.ideascale.com/a/dtd...a-tab-comments |
#29
+100
#30
Bob Without a song The day would never end Last edited by Bob L; 08-23-2018 at 02:28 PM. Reason: fix |
PT HD system power equivalent. | Philee | Pro Tools TDM Systems (Mac) | 3 | 09-29-2010 12:22 PM |
ICON equivalent of "Center Edit Start/End" | Drew Mazurek | ICON & C|24 | 2 | 09-14-2009 03:41 AM |
Keyboard equivalent to edit pack machine track arm | macaholic | ProControl, Control|24, Command|8 | 0 | 07-24-2006 02:52 PM |
ProTools equivalent to DP's "SNIP" | 10acErnie | Tips & Tricks | 3 | 01-15-2004 06:01 AM |
why isn't there a midi "touch tracks" equivalent for Protools | fathermac101 | Pro Tools TDM Systems (Mac) | 9 | 04-07-2003 01:30 PM |
