I've been gradually developing an opinion regarding the sonic quality of Elastic Audio. I wanted to make sure that I had used it on many different instruments, with trying all the available processing options, to confirm my initial results.
First, let me qualify my remarks by saying that I edit human performances on "real" instruments... no loops, samples, etc. EA may indeed work fine on that material. IMHO, EA **with Digi's algo's** is great for quick & dirty fixes (i.e. demos), or to generate a visual display of where a part can be quantized to, so I can then do an old-school edit, using the EA track for visual cues if needed. But, after repeatedly trying EVERY available processing option within PT 7.4, I've yet to find one that doesn't leave un-listenable artifacts on virtually all acoustic (and most electric) instruments I've attempted it on. It takes about as long (or longer) for me to tweak the markers, run EA & then "clean up" the garbage in an EA processed track as it does to just slice 'n dice the way I always have. And sonically, there is simply NO comparison. I apologize if this sounds harsh, but... Digi, are there ANY plans to incorporate third-party algorithms (Serato's would be my first preference) and thus make it usable at a pro level?! Anyone else interested in expanding the sonic options for Elastic Audio??! Warmest Regards, Brian |
I gotta say, I use it on vocals all the time to adjust timing/feel and even durations in the context of pop and rock stuff and unless I really try to push the boundaries (of good taste?) it sounds great. ElBass too. AcGtrs and pianos get a little trickier, but often very usable depending on the context.
@wildhoneymusic http://kidzbop.com/music/ http://razorandtiemusicpublishing.co.../gary-philips/ |
![]() Quote:
Sometimes you get some small things (which are are able to solve) - but most of the time it's working really good. Cant's wait to have EA i PT8..... |
![]() Quote:
e
ihatetyping |
I've had some great results on everything but acoustic guitar. Not sure why...I've tried every algo and every setting, but still...
![]() some clients can't hear it though...and after asking to quantize real drums and melodyne all the vocals, I'm sure they don't even care. Most of the song is so processed already that it doesn't matter!
cheers, rich |
![]() Quote:
EA is a terrific tool for certain kinds of things, and yes, I wish the Polyphonic algorithms would be improved. best, rich
http://www.richbreen.com ---------------------------------------- MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24, 3xS1/Dock. |
[QUOTE but Pitch 'n Time is significantly *worse* on drums using the rhythmic EA algorithm. Try stretching a drum track 10% or so with Pitch 'n Time - listen to the pre-echos and phasey-ness generated, now try the same thing with EA (you may need/want to tweak the decay parameter) - much better.[/QUOTE]
Hey Rich, You're absolutely right about PnT NOT working on drums...!! Digi's EA algorithm is indeed better for that. FWIW, I always hard cut drums, as it's the only way I can get enough control to push and pull grooves & fills to taste (feel) & tolerances (yes, 2 ms IS a long time... lol). That said, PnT is the best I've found for acoustic guitar, grand piano & the like, and even then proper results often require stretching the sustain & decay, not across transients. And on a given instrument or voice I'll usually use 2 or even 3 different TC/E tools to maintain sonic integrity. Each one has a "sound". The point of this thread is, I'd love it if we had some options within EA to bring it to the next level... thanks to everyone for chiming in on this. Warmest Regards, Brian |
![]() Quote:
![]() Quote:
I actually keep getting surprised of the results and how great they turn out. Cheers |
i heard from digi at a pro tools users group meeting in l.a. that pt8 has improved ea algorithms. i can't get it to sound very good on multi-tracked drums so far, and i've tried everything!
ELASTIC AUDIO - A GOOD QUALITY RESULTS ? ON BASS TRACKS ? | djani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2007 07:16 PM |
sonic quality of revibe at 44.1?? | blumediaprojekt | Pro Tools TDM Systems (Mac) | 7 | 02-27-2006 12:07 AM |
Sonic quality Loss??, On reboot Sounds good again? | mach-1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2005 11:58 AM |
Sonic quality of REASON (rewired) into PRO TOOLS | rodamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-17-2005 09:55 PM |
sonic quality difference bet/ a.pack and h-ware? | minister | Post - Surround - Video | 2 | 12-28-2004 09:25 AM |
