Old 03-13-2008, 04:28 PM
Sevenlights Sevenlights is offline
Default 7.4 tab to transient backwards bug
I have found a bug introduced into 7.4 LE and is still in the CS-3 version. When I'm doing a task such as editing drums, after I separate a region I try to tab to the previous transient (option tab) I get this error.
could not complete your request because (-50) while reading "xxx"wav
xxx could be any wave file in the group and only seems to happen when I have a large amount of tracks groups like 12 for drum editing. It happens is every song, I've never had a problem with it before. I happens every often and makes if hard to run my editing quickkeys scripts.
Update:
I just found an easy way to reproduce the error, after making a bunch of cuts to your region group, tab to transient backwards through the regions and the error should show up eventually it happens in some of my songs more than others.
If you make a cut in the offending region it will allow you to tab back to the new region cut and give the error again.
Anyone else seen this problem I can't find it documented anywhere. It's really annoying.
Scott Cooke.
Mountain View Records
EA and tab to transient Stig Eliassen Pro Tools TDM Systems (Mac) 9 03-11-2011 04:48 PM
tab to transient.. peter99 Pro Tools TDM Systems (Mac) 2 09-30-2010 10:28 AM
Algorithm difference between tab to transient and option + tab to transient? taiga_with_a_pen Tips & Tricks 2 02-13-2010 11:35 AM
tab to transient keny Pro Tools TDM Systems (Mac) 6 03-06-2005 02:11 PM
Tab to transient niki111 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2002 06:03 AM
