Old 07-19-2005, 11:06 AM
djbroc djbroc is offline
Default output panned to the right slightly?
one of the monitors that i use for playback is playing louder than the other...why could that be?
Old 07-19-2005, 11:20 AM
DigiTechSupt's Avatar
Default Re: output panned to the right slightly?
What types of monitors are they? Is one of your amp channels or the input sensitivity on the monitor (if it's powered) higher than the other?
Avid Audio Tech Support
Support FAQ
Old 07-19-2005, 11:22 AM
Sevenlights Sevenlights is offline
are your monitors close to the wall in a corner, you could be hearing a build of up frequencies. Physically switch your speakers around and see if the problem follows, if you have a seperate power amp switch the speaker cables too to see if the problem follows the speakers. If you switch your speaker and the problem is still in the same place, could be a room related problem.
Scott Cooke.
Mountain View Records
Old 07-19-2005, 11:33 AM
yOkO yOkO is offline
should assume you've check all your pannings, the PT master fader meterings,
the mixer or preamp meterings and the poweramp or individual levels of your monitors levels
so what
Old 07-19-2005, 12:02 PM
i have KRK V6s and i have them plugged directly nto the back of my digi002. i know its not just me hearing it cuz i see that the woofer on the right one is bumping harder then the left one. Im frustraed. i know its not the track too, cuz there is nothing panned at all.
b
Old 07-19-2005, 12:15 PM
First thing is to swap the monitor cables left and right, and see if the problem is one of the monitors, or the output from the 002. Then eliminate cables by swapping. Double check any level or sensitivity controls on the monitors.
Then, try the monitors using a different pair of outputs on the 002, like maybe 5 and 6.
With all the available outputs, and all the swapping that can be done, this problem should be easily isolated.
Quad 2.5 G5, 4.5G RAM
Old 07-19-2005, 02:40 PM
Bezo Bezo is offline
Someone aslo told me that the pan pots are not exact. Can anyone verify that?
PTLE 8.0.5, Digi 002 Rack
iMac 3.06Hz Intel Core 2 Duo w/8GB RAM, OS 10.6.8
Glyph GT050Q Drives
Old 07-19-2005, 06:41 PM
The panning in ProTools centers exactly.
Old 07-19-2005, 09:31 PM
UnlikeKurt UnlikeKurt is offline
not to sound like a moron or anything, but if all else fails, and everything seems to be ok, maybe it's just your ears..
i know that my right ear hears slightly less than my left...so it always seems like the left is louder in my mixes to me...but to other people they are dead on....i've learned to compensate
Panned tracks bounce to iTunes are no longer panned Patamuus Pro Tools 10 1 04-24-2012 12:30 PM
multiple guitar tracks panned ?? CrAkD Tips & Tricks 4 05-19-2005 08:11 AM
Center Panned Tracks Sound Dull. Any ideas? heartparts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-28-2005 12:40 AM
Consolidating Panned Tracks - Finalized In Stereo? ansanity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-04-2005 09:12 PM
Centre Panned - now the sound level is dropped Da Gatekeepa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-26-2002 06:38 PM
