Setting up Mixer with Pro Tools through Interface
I am completely new to recording on pro tools with a mixer, before I just used a interface on ableton live lite so i am totally lost trying to set this up. Sorry if this has been asked before, I've tried looking online and setting it up on my own but no luck. I am trying to hook up my mixer to pro tools, and i was told the way to do this would be to hook up my mixer to a interface and the interface to my computer. i also read i would need monitors for my setup so i got a pair. im not sure if the monitors need a power amp?
I hooked up the interface to the mixer through the line out on the interface to the stereo out of the mixer with quarter inch cables. then i plugged the monitors to the monitor out of the mixer, even if I did plug everything in correctly I still wouldn't know how to set it up in pro tools. Here is my setup: Mixer: Yamaha MG166CX Stereo Mixer Interface: Saffire 6 USB Monitors: KRK Rokit 6's Windows 7 with Pro Tools 10 Guitar, mic, and quarter inch cables. I also have a Crown XLS 1000 Power Amplifier i could borrow if needed. Any help would be greatly appreciated, I have all the gear I just can't figure out how to get it all to work and it sucks because I really want to record with friends and have fun with it. If anymore information about my setup is needed let me know. |
Re: Setting up Mixer with Pro Tools through Interface
Can you describe the way in which you want to record? I mean, are you using the mixer to record with or mix? I'm not sure your current setup is going to give you the flexibility you want - on the other hand, it may be too much as the mixer might not even be needed. Also, you don't want to plug an output to an output as you've described - outputs go to inputs. The Rokit 6's can be powered or passive - it should indicate on the back what yours are.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
New to Pro tools: Need help setting up interface | KevinJamesFan6 | Getting Started | 3 | 06-07-2013 04:23 PM |
Please Help with Setting up Mixer for Band Compression | tonesponge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-15-2010 12:15 PM |
Help setting up Mbox and an external mixer | asiabackpacker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-23-2005 11:28 AM |
How do I save my mixer setting? | Highlandic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 02-14-2004 05:36 AM |
Setting up a MIDI mixer template | sidereal-studios | MIDI | 0 | 07-08-2003 09:37 AM |
