Old 09-23-2017, 12:46 PM
willl3 willl3 is offline
Default Re: right click select whole clip when trying to cut it
Originally Posted by joachim View Post
Could you clarify : do you then click at this position or are you going right away for a right-click ?
If you go on the position and click and then right-click, it should work.
If you go on the position and click , but move the cursor away from the vicinity of the position and then right-click, it cannot work.
The blinking cursor is at the position I want to cut in grid-slip-shuffle any mode doesnt matter
I put the cursor is the middle of a clip
its blinking nicely where I want to cut
as soon as I right click it selects the whole clip what is this? something with 12.8?
ALL I WANT TO DO IS RIGHT CLICK WITHOUT IT SELECTING THE WHOLE CLIP
I have to go to edit pull down select cut clip at selection (or control e)
I deleted prefs
fixed other issue I have on this board but this is an f'n nightmare
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram
Old 09-23-2017, 01:18 PM
I deleted prefs
I asked this question before and you didn't answer it - do you have the track name highlighted? Are you using the smart tool? If so, don't. Just use the I-beam tool.
Old 09-23-2017, 05:13 PM
track is highlighted
smart tool on or off doesn't matter
blinky line on clip (middle, 3/4, 1/8) any where in the clip
I right click
the whole clip gets selected
What did AVID change this?
(I've been using protools since ver 6)
so this is driving me crazy.
looking under preference edit I cant find it any where
WHY WHY WHY!!!!!!!!!1
Old 09-25-2017, 01:46 PM
Dear Moderator,
Please move this into Protools software(win)as this seem to be a defect in this version of protools for win10
this is not a tip or a trick but a possible issue
also how do I delete my signature below there is no edit button
Old 09-25-2017, 01:51 PM
Dear Moderator,
You change your signature in your profile page.
Old 09-26-2017, 03:31 PM
Current Response:
Entered on: 9/26/2017 11:45 AM Entered by: Osamu Kawabe
Hi Will, Thanks for making contact with Avid Customer Care. We are sorry for inconvenience. Our development team is aware of the issue: PT-233024 Right-click > Separate option does not work (new to PT 12.6) It is planned to be fixed in the next update of Pro Tools. Please use " Command + E " short cut as a workaround till the issue is fixed. Thanks, Osamu AVID
problem is that this protools 12.8 and still not fixed
when is the next update?
Old 09-26-2017, 06:09 PM
Current Response:
problem is that this protools 12.8.1 and still not fixed
Old 10-04-2017, 04:58 PM
It does not allow me to change the signature there is no edit pencil
Old 10-04-2017, 05:18 PM
You don't use an edit pencil - no such thing. Got to your user CP (control panel)and select the 'edit signature' tab on the left side of the page. In the right side which is about 80% of the page is a section titled 'edit signature'. Just click your mouse in there to place the cursor where you want to add/delete/change things and type away. You can preview your signature before saving it. It's that simple.
Keyboard Shortcut to Select the Next Clip in Clip List TomMxEdit Pro Tools 12 1 02-27-2017 11:52 AM
select next clip in timeline (on all tracks) johannes1 Pro Tools 10 3 07-07-2015 09:48 AM
How do I select multiple regions in the clip list? Moviesound Post - Surround - Video 5 08-25-2012 05:31 AM
How select a clip with Artist Control? John Fishback Artist Series 4 05-21-2012 09:23 AM
grabber doesn´t select clip with fades Frank Kruse Post - Surround - Video 0 07-14-2005 08:44 AM
