Old 04-16-2003, 08:57 PM
storm-01 storm-01 is offline
Default -9093 Error, CPU stops rec., says buffer problem?
I just got the 001 today, installed everything and it worked fine until I tryed to record. I set the buffer setting to 256 and started to record only to have the computer to stop and give me a -9093 error. It says "the operating system held off interrupts for too long. If this occurs often, try increasing the H/W buffer size". I made it the highest buffer size and it still stops (no matter what buffer size it is). Any advice?
thanks,
Stormy [img]images/icons/confused.gif[/img]
Old 04-16-2003, 09:33 PM
Default Re: -9093 Error, CPU stops rec., says buffer problem?
I guess I should have checked the DUC before asking. It was because I use my cable modem on the same computer. I disabled it, and it works fine.
stormy [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img]
Pro tools 9093 Hardware buffer size to low problem gulagurk Windows 8 06-13-2011 09:12 PM
Still getting error 9092 & 9093: "increase HW buffer size" pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 07-07-2007 10:36 AM
Still getting error 9093: "increase HW buffer size" pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-16-2007 03:02 PM
Buffer error 9129 & 9093 when turn down buffer StackLife06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-01-2006 09:34 PM
error -9129 /-9093 and "increase/decrease buffer" nickgodie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-07-2006 03:59 AM
