Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 06-20-2019, 08:53 AM
fourthtunz fourthtunz is offline
Default 2014 macbook pro+midi+11rack..anyone using this combo?
Im using a 2014 MacBook pro 15" quad I7 2.8 with an 11 rack and trying. to get an M audio axiom pro controller to work but I can't get protools to see the controller..although when I play a chord it show the chord name on the edit screen but when I try to get it to work with boom or mini grand or any of the stock instruments the controller won't play any of them and protools goes into spinning beach ball..
Ive tried this with both Protools 12.8.3 and 2019.5 same result no worky with controller but can record through the 11 rack without the controller hooked up.
I can get the controller to work without the 11 rack..works with protools and live and logic . Are the Usb ports on this 2014 wonky?
this setup worked fine with my 2012 MacBook pro. I am using a usb hub which worked fine before
setup..2014 macbook pro On Sierra, 16 gigs ram..external usb drive, usb hub, internet disconnected, any ideas?
Fans Going Wild .. ver 19.5.0.322 on macbook pro 2014 john1192 Pro Tools 2019 4 05-31-2019 09:34 AM
macbook pro mid 2014 2.8ghz s0und80y Post - Surround - Video 4 12-09-2015 12:43 AM
MacBook Pro Retina Mid 2014 not qualified? Why?? Mattian Pro Tools 12 32 11-23-2015 11:33 PM
2014 MacBook Pro for Editing Only TerryBarnett Pro Tools 11 2 12-17-2014 11:11 AM
11Rack w/MacBook DUlrich Eleven Rack 42 01-19-2011 06:40 AM
