Old 06-04-2019, 01:03 AM
kinomatic kinomatic is offline
Default Dolby Atmos mapping to objects troubles
Using ProTools 2019.5 and Dolby Atmos Production Suite 3.0 I have problems opening Atmos sessions. It can not map to objects saying "the current session has an output bus mapped to this output and it may not be remapped to an object". I have tried to import originals setting, restore from session, delete unused buses etc
What more can I do to clean it up? Atmos without objects it is pretty useless...:)
Best/Rune
Old 06-04-2019, 06:29 AM
reichman's Avatar
reichman reichman is offline
Default Re: Dolby Atmos mapping to objects troubles
Without actually looking at your rig, it's hard to be sure, but I suspect problems in your I/O page.
Obviously check the Dolby templates to make sure those are working on your system.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 06-05-2019, 01:19 AM
Adam at Dolby Adam at Dolby is offline
Hi Rune,
I have a short knowledge article on the developer.dolby.com site about this message.
https://developerkb.dolby.com/suppor...t-be-remapped-
However this is usually seen within a session and not opening one. Just to be clear is this seen when opening a session and not importing a ADM BWF as session data within and existing session?
If this is seen when opening a session, I'd advise creating a new session with a track with no input/output assignments, clearing the bus page of the I/O settings completely. Saving and then trying to reopen the problematic session. See if the problem persists.
Again this is usually seen within a session mapping an object on a bus this is already assigned as a track output. This should be cleared out when opening a new session.
HTML code is On
Dolby Atmos with S5 MC-Pro critictalk Post - Surround - Video 4 01-01-2018 08:21 AM
Dolby Atmos IrelandM Avid Pro Mixing General Discussion 2 07-17-2017 01:00 AM
Dolby Atmos - Do I need SRC? budster Post - Surround - Video 4 03-24-2015 10:25 AM
Dolby Atmos peter5992 Post - Surround - Video 20 10-29-2012 01:51 PM
Dolby Atmos mikevarela Post - Surround - Video 3 06-25-2012 07:13 PM
