Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
  #21
Old 05-14-2019, 03:27 PM
G374 G374 is offline
Default Re: Not able to create new tracks in Pro Tools 2019.5
Yeah, and if you try to go to that path it say database is being created and the error will go away once it completes. Very strange! Maybe it will get fixed in the next update.
  #22
Old 05-15-2019, 07:49 AM
gnoub51 gnoub51 is offline
I had the same issue and also couldn't add or remove a plugin, New or Old session. No difference. Avid has some content relative to files to delete with assertion issues. But that didn't help until I trashed all folders with the name AVID or PRO TOOLS.
Here's what I did that worked:
1. Close Pro Tools
2. Delete files as described by Avid (Database, WaveCache, Perf's, etc). They also listed two I couldn't find.
3. Trashed Pro Tools app.
4. Deleted all folders with AVID or PRO TOOLS names.
5. Reinstalled PT 2019.5
I'm now working properly (so far).
My rig is:
2016 MB Pro
10.14.3
16 G ram
2.7 i7
And I track to an external SSD.
Hope this helps.
  #23
Old 05-15-2019, 04:22 PM
1. Close Pro Tools
My rig is:
2016 MB Pro
10.14.3
16 G ram
2.7 i7
Hope this helps.
Where is this info located?
  #24
Old 05-15-2019, 04:26 PM
Much of this is standard pref/database trashing.
Get Peter Gates PT Prefs utility, check every option. http://petegates.com/pg-pt-prefs.html
  #25
Old 05-22-2019, 05:12 PM
Today I received a call from Avid support (Jimi) and he removed the track preset folder from documents > pro tools folder and the error stopped. So now I’m able to create tracks and add plugins. Thanks Jimi!!
Pro Tools 2019 ! abomeerza Pro Tools 2019 1374 05-14-2019 07:13 AM
protools 2019 384 tracks per hdx card? FilterDecay Pro Tools HDX & HD Native Systems (Mac) 6 02-08-2019 11:31 AM
