Old 03-03-2018, 12:38 AM
TCLguy1 TCLguy1 is offline
Default High Sierra - Audio Midi Beach ball
After updating a computer from 10.9.5 to High Sierra we get nothing but beachball when opening Audio Midi Setup. Trahsed prefs and all Midi Drivers. No Change. No DAW opens.
Any thoughts on what could cause this?
THX!!
Best,
TCLguy
_________________________________________
12-Core Xeon 3.33, Antelope Audio Goliath, Logic, Live, PT12HD
Dual 2.7 G5, ProTools HD3, 2*192's, SSL Delta Link
iMac 3.0 , Abelton live
MacBook Pro, Logic X for Video
Old 03-03-2018, 01:44 AM
Sardi Sardi is online now
Default Re: High Sierra - Audio Midi Beach ball
Clean install of HS or upgrade over the top of Mavericks?
If the latter, clone your drive/data so you have a backup, then erase your boot drive and install HS from scratch.
This is the main reason I NEVER do OS upgrades greater than point revisions without a clean install. Too many gremlins. Even more so jumping 4 years in OS updates.
Old 03-03-2018, 08:32 PM
yeah...will do that THX
Best,
TCLguy
Old 03-03-2018, 09:42 PM
NP.
Let us know if that solves the problem.
Honestly, it’s a little bit more work doing the setup this way, but at least you start with a fresh system. I rarely have issues and I’ve being doing it this way for the better part of 2 decades.
Best of luck.
Old 03-20-2018, 05:27 PM
685 685 is offline
what midi devices do you have connected?
When I first upgraded to High Sierra my Midi I/O was good to go. When I installed the supplemental update a while later I started to get the beach-ball freezing. I was lost at first as I never had any freezing problems with the midi. Protools was also freezing at the initializing midi portion of the startup.
I ended up re-installing the OS to sorta reset it prior to the supplemental update but the same thing was happening. Ended up doing a completely reformat and clean install (much needed in my case) but the same problem is happening.
Work around:
No problems at all after a fresh booth. If I open/use/close Protools I would have beach-balling/freezing If I tried to reopen Audio Midi Setup or Protools. If I hit reset on the Midi I/O then Protools or the AMS will open. I connected the Midi I/O to my Macbookpro and I don't have any problems at all and it the 10.13.3 supplemental update installed.
Lag and Beach Ball Intransit Pro Tools 12 1 03-15-2016 03:58 AM
Open Midi Tracks in PT 12 Beach Ball MusoPro Pro Tools 12 0 07-19-2015 08:09 AM
Spinning Beach Ball after using Auto Tune in Audio Suite Rule62 Pro Tools TDM Systems (Mac) 1 01-01-2013 05:00 PM
Spinning beach ball of death when importing audio from video uvstudios Pro Tools HDX & HD Native Systems (Mac) 0 12-25-2011 11:16 PM
Clicking Midi I/O causes 5-10 second spinning beach ball jhorsley Pro Tools 9 9 12-01-2011 04:35 AM
