Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
  #41
Old 06-09-2019, 03:19 PM
BScout BScout is offline
Default Re: Dock monitor control
Only the monitoring tab stays locked so you can control volume. And when you are on that monitoring tab, the side knobs control monitoring. Also the Monitor control knob on the Dock stays locked at all times so you can control volume and mute.
All others tabs move with the application you are mixing with. (which you can lock separately to Pro Tools.) If you want to have all the tabs and faders locked to monitoring, lock "entire surface" to the Xmon instead of "Control Room."
Why anyone would want to do that is beyond me.
I also think you are not getting it: lock Control Room. Not Entire Surface. On the Assign Tab.
That is if you want the faders, etc. to go with Pro Tools. Sounds like you are locking the Entire Surface.
Post a screenshot of your Assign tab in Eucontrol if you want more help. No other way to figure out what you are doing.
Pro Tools Ult 2019.5, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
  #42
Old 06-09-2019, 03:25 PM
sjcollins92 sjcollins92 is offline
Thanks, That was it, i was locking everything, its working perfectly and thanks again
Can you use the MC Control with S3 instead of the Dock? KeyplayerG Pro Tools | S3 4 01-11-2018 04:34 PM
Dock with Artist Control Sugarfree Pro Tools | Dock 2 09-21-2017 05:31 AM
Control App/Dock ques: Custom pan jkess Pro Tools | Control 1 08-27-2017 09:45 PM
Is The Dock really any better than the MC Control? KeyplayerG Artist Series 7 04-28-2017 03:51 PM
Is The Dock really any better than the MC Control? KeyplayerG Pro Tools | Dock 1 04-24-2017 05:42 PM
