Old 11-20-2017, 05:16 PM
jpmorgan jpmorgan is offline
Default importing downloaded .mp3s
I downloaded two mp3s of various breaking glass sounds from the internet, but when I try to import them into my session, I get this message: "Cannot open the selected file because file is not a ProTools Session or OMFI file." I've imported mp3s I've downloaded before, but I've never had this problem. What should I do?
If anyone knows where there's an .nki file of shattering glass sounds I could download, it would be greatly appreciated!
Old 11-20-2017, 06:08 PM
john1192 john1192 is offline
Default Re: importing downloaded .mp3s
jst drag them into the Tracks list or Edit Window ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 11-20-2017, 08:15 PM
strangepumpkin strangepumpkin is offline
Are you using the Import Audio function found in "File". The fact that the error states the file is not a Pro Tools session is making me think you're using the incorrect method of importing mp3 files.
Kyle Whittaker
www.strangepumpkin.ca
Mac Pro (2013)
3.5GHz 6-Core Intel Xeon E5
32 GB Memory
OS X 10.12.6
PT 2018.1
Old 11-20-2017, 11:15 PM
lesbrunn lesbrunn is offline
You're probably doing an 'import session' instead of 'import audio'
X99 | i7 5820 | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro 256GB | Kingston 120GB SSD | Samsung 850 EVO 1TB | Samsung MZ7PD256HAFV-000H7 SSD 256GB | WD Black 1TB x2 | G-Drive 4TB | Audient ID14 | PT12.8.1 | Windows 10 Pro
Old 11-21-2017, 01:23 AM
Just drag and drop the mp3 file icons onto the Pro Tools edit window...., or on an existing audio track on the edit window if you want to place them somewhere specifically.
Old 11-21-2017, 02:53 PM
One mistake I made was that I had created an Instrument track, not an Audio track. So I deleted it and made an Audio track. The "not a ProTools Session" error message no longer appears. Instead, the window shown in the attachment appears where nothing works. Clicking on Add Files, or Add Clip only un-highlights the desired mp3 choice. Done only shuts the window. I've tried dragging the mp3 file onto the track, as I've always done before in other sessions, but nothing happens, nothing at all.
Old 11-21-2017, 02:55 PM
By the way, I am using Import Audio.
Old 11-21-2017, 03:17 PM
The Weed's Avatar
The Weed The Weed is offline
Are you running PT as Administrator? If so, uncheck that in Properties>Compatibility as, if checked, you can't drag and drop in Windows.
That said, the Import Audio dialogue should work. Did you click on Add or Convert in the dialogue to add or convert the MP3 file?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 11-21-2017, 04:30 PM
sorry .. i was thinking MAC when i mentioned Drag and Drop .. sucks you cannot do that on PC ..
Old 11-21-2017, 05:00 PM
The Weed's Avatar
You can drag and drop on PC, just not if you are running PT as Administrator.
Pro tools not importing MP3s emilicuadras Windows 1 08-10-2011 12:19 PM
Importing downloaded songs into PT from iTunes lwilliam General Discussion 4 01-30-2008 06:35 PM
Importing MP3s corrupts saving option mariang Pro Tools TDM Systems (Mac) 0 05-16-2007 03:52 PM
importing mp3s MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-20-2005 03:46 PM
Importing MP3s; files truncated davfries 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-04-2004 01:16 PM
