Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
Old 01-19-2017, 03:09 PM
J-S-Q J-S-Q is offline
Default Where can I download older versions of Eucon?
As the title says...
Troubleshooting a problem and want to try Eucon 3.4 Where can I find the installer please?
Old 01-19-2017, 03:22 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Where can I download older versions of Eucon?
I would start a support case and they should be able to help you
Daniel
Old 01-20-2017, 12:03 AM
Southsidemusic's Avatar
If you login to the Euphonix/Eucon account you can find older versions.
You do not have to start support cases for things that exist in your accounts already.
Have you tried that? You will find versions back to 2.7 and up.
http://euphonix.avid.com/main.php
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 01-21-2017, 02:16 PM
Thanks, that is the solution. I was mistakenly logging in to my Avid Master Account which only shows the latest Eucon version.
Old 01-21-2017, 03:22 PM
Glad to help
Yeah the Avid Accounts only list the latest Eucon version as you said.
All the best and hope everything goes well.
Best Regards
Christopher
WEBHOME
Older PT versions and OS X 10.9 digitalpan macOS 1 03-13-2015 01:43 PM
older prottols versions bighub Pro Tools TDM Systems (Mac) 1 08-20-2014 02:48 PM
Question about an older Mac Pro and possible older versions of Pro Tools HD wolfman_rob Pro Tools TDM Systems (Mac) 13 07-21-2013 01:29 AM
Older versions available? adhali Digidesign Hardware & Software 1 11-30-2003 11:13 PM
MBox and PT 5.2 vs. older versions UIowa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-20-2002 09:59 AM
