PT hangs on transport stop when editing a track with many playlists in playlist view
Hi - i have a session i've frozen almost completely except the lead vocal I'm working on. When i have that Lead track's playlists displayed for comping, the session lags a lot as soon as transport is stopped. almost like it's thinking (w/ Rainbow wheel) but there's nothing to think about. no Clip FX, no EA enabled on anything. CPU usage is extremely low, all files are on an SSD. PB buffer is 64, and its a fairly new quad core i7 macbook pro. There are 100 or so playlists of mostly whole takes. Only odd thing about this session/track is that the playlist number goes very high up to this point (lots of re-dos and edit from multiple people). The latest playlist is up to #82148 and some playlists have negative numbers (like -1023 for ex.). i don't know if this has anything to do with it but also don't know how to reset the playlist numbers.
Anyone else experience this? Worked on the same song/computer in PT10HD with no issue, and this is a "save copy" of that session for PT12HD. Switching back to waveform view stops the issue and freezing everything else did not help. thanks! Last edited by bolooki; 10-24-2016 at 06:28 PM. |
Re: PT12.6 HD edit lag in playlist view when transport stops
update -
just reproduced this bug in a blank session in 12.6 HD, non-HDX: - if you create a new track and create 100+ blank playlists, PT hangs for 3-4 seconds with a spinning ball when you stop the transport even with no Audio in the session. Hiding playlists or inactivating the track while still in Playlist view does not help, but deleting all the playlists or switching back out of playlist view eliminates the issue. The less playlists, the less time it hangs. i frequently edit vocal tracks with 100-200 playlists but this is the first I'm noticing it since upgrading to 12.6 from 10. anyone else seen this issue or have a solution? |
Re: PT hangs on transport stop when editing a track with many playlists in playlist v
edit edit -
trashing everything w the pref delete app seemed to do the trick if this happens to anyone else. :) |
Same issue on this end as well.
I first came across this problem when using an HDX system on a 2012 12 Core Mac Pro. Yesterday, the same problem happened during a session. We switched out the computers, opened the session, went into the playlist - same result. Will try to trash preferences and see if that helps. Thx bolooki |
I am still having the same issues. I too am coming from Pro Tools 10HD to 12.
Is this a playlist bug? I've been trying to find more complaints about this on the Avid forum and I'm not seeing much. Do people not use playlist in Pro Tools? |
Playlist editing problem with S6 | Stereo Missile | Avid S4/S6 | 6 | 11-28-2015 04:57 AM |
Printing a track to a playlist? | gdgross | Pro Tools 11 | 14 | 04-07-2015 05:12 PM |
Can a track have a consistent name regardless of playlist? | jschmidtiii | macOS | 5 | 10-30-2013 05:10 PM |
Playlist Editing...Pretty Please ..:) | lemix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-09-2005 11:41 AM |
Retaining Selection in PlayList Editing | sydphi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-09-2003 08:21 PM |
