Old 03-02-2016, 01:46 AM
K_BCN K_BCN is offline
Default Is there anything we can do about Artist losing connection?
Artist Control + Win 8.5 here. Dedicated LAN interface, tried with both dynamic and static IPs. It just disconnects after a random time.
I am reading through this forum and its really discouraging. Same issue on many many different computers/setups. I wonder if this just happens to everybody, or if maybe there´s a batch of faulty units..dont know.
Can i, as a user, do anything about it? I wouldnt like to start a eternal email conversation with Avid´s support before asking here.
Thanks
Old 03-02-2016, 02:58 AM
J-S-Q J-S-Q is offline
Default Re: Is there anything we can do about Artist losing connection?
Are you using Wifi? The only EuCon troubles I've had were related to Wifi. If I connect to Wifi whilst EuControl is running, the controllers can lose connection. If I start the Wifi first and then EuControl, everything is fine.
Might be worth disabling your Wifi and see if that fixes the problem.
Old 03-02-2016, 09:14 AM
ALSTUDIOS ALSTUDIOS is offline
Hi
I do notice as well more often than in previous EuControl versions, that the connection between the DAW application (in my case Cubase PRO 8.5.10) and the Artist controllers get lost.
I didn't figure out, what's really the basic problem with that, as well as it is not reproducible.
Some time, I log-in to the internet or log-out of the internet, which doesn't have any relation to the Ethernet port (is all made by USB-port) and loose the connection. Sometime I can do it several times and keep the connection.
I'm not a PC/IT guy. Therefore I just have to wait either for a bugfix on EuControl or the now using workstation goes down and I have to buy another one
Cheers
ALSTUDIOS REGENSDORF SWITZERLAND
a.l.recordingstudio.ch@gmail.com
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win7 64Bit, Cubase Pro 10.0.20
Old 03-03-2016, 08:26 AM
philgrab philgrab is offline
Thanks
Make sure your USB and Ethernet port options don't allow the computer to shut them down to save power.
Old 03-06-2016, 11:23 AM
owensoundstudios owensoundstudios is offline
For cubase, i read somwhere, that on a mac using a usb sound card there is somtimes an issue with the soundcards via USB when the computer is idleing, I wonder if that type of thing could be affecting the Eucon.
I don't lose connextion and I have the eucons directly into a small switch, which is plugged into the mac. I do, however, have cubase crash affter leaving it idle for a few hours.
Also, I don't have my Eucon load automatically- and one thing I've noticed, when it reloads, it never remembers to re assign the four faders on the control.
Old 03-08-2016, 02:30 AM
Thanks for the replies.
I am not using Wifi at all.
Can you please explain how to to that in Windows 8?
Help Avid Artist Control losing connection with logic X using usb to ethernet adapter smartinez5878 Artist Series 4 06-23-2014 11:10 PM
Artist Control v2 losing connection with PT 10 (Mac) Trazan Artist Series 5 05-22-2014 12:53 AM
Keep losing connection with my 002! chanlon25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-02-2006 04:21 PM
Losing USB Connection stealth_162 ProControl, Control|24, Command|8 3 03-02-2006 09:56 PM
My 002 keeps losing the connection partytrain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2004 01:03 AM
