Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 06-01-2015, 08:36 AM
Amechan Amechan is offline
Default Fast Track Ultra 8R Windows 10 drivers?
Will the M-audio Ultra 8R get a windows 10 driver or will the win 8 driver work?
Old 06-01-2015, 09:43 AM
JoelG's Avatar
JoelG JoelG is offline
Default
By the Avid End of Support date, the FTU 8R should still get support: http://avid.force.com/pkb/articles/e...-support-dates
Product / Model Final Sale Date End of Support Date
Fast Track Ultra 8R 2/11/2013 2/11/2018
But, I wouldn't jump right onto the Win10 bandwagon without testing it first (clone your drive before upgrading so you can roll back).
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 06-01-2015, 12:24 PM
GEORGEBAKHTADZE GEORGEBAKHTADZE is offline
Default Mbox 3 mini Voice issues
I've deleted my integral realtek sound driver and then install m box mini driver but it still dont work. You always say about protools i'm sorry but i dont mind anything about protools , we can forget any DAW my goal is listen music which i could not. Nobody can help me?
Old 06-01-2015, 12:39 PM
JoelG's Avatar
Default
Please dont hijack threads, see the thread that you started and post back: http://duc.avid.com/showthread.php?t=368272
Joel
Jame Space:
Home:
Rig:
Old 09-22-2015, 12:06 PM
MikeMaMan MikeMaMan is offline
Default Re: Fast Track Ultra 8R Windows 10 drivers?
I got Fast track Ultra. Old driver for win 8 work. But with problems. I do loose sound now and again in games. So i need to change output in "playback devices" menu in Windows. don't know if it'l get fixed later.
Old 10-15-2015, 06:06 AM
bcs_yann bcs_yann is offline
Hello MikeMaMan!
I have the exact same problems and fix with my Ultra 8R under Windows 10. Nice to hear I am not the only one. It is annoying as hell and I really look forward to a driver update.
That said: It's not like Windows 10 came upon us out of nowhere, this is very shoddy device support. The driver should have been ready by August 2015 at the very least. The Ultra 8R is, as JoelG pointed out, to be supported until late 2018. I am this close to throwing it out and turning away from Avid/ M-Audio.
Cheers everyone
Yann
Old 11-09-2015, 12:47 PM
I have the same problem as MikeMaMan.
I have noticed with a lot of trial and error that the problem seems worse with things that use hardware acceleration. Flash and Firefox being major offenders. I have also turned off "allow applications to take exclusive control of this device" off in advanced windows playback options. This has made the drop outs less frequent but it still happens once a day or so.
The quick solution is to disable and then re-enable the sound device in playback devices but obviously this is not ideal.
Since installing Win 10 64 last month I have had 4 blue screens of death. Each one giving some IRQ conflict error pertaining to M-audio drivers.
Hopefully when a proper driver is released the above issues will be solved.
Old 11-09-2015, 12:58 PM
I should also mention this is a clean install of win 10 64.
Sandra info bellow in case it helps the developers in some way.
SiSoftware Sandra
ID
Host Name : DESKTOP-J4523RM
Workgroup : WORKGROUP
Computer
Model : OEM
Serial Number : To be fille***********
Chassis : Desktop
Mainboard : ASUS SABERTOOTH 990FX
Serial Number : MT70260********
BIOS : AMI (OEM) 1604 10/16/2012
Total Memory : 12GB DIMM DDR3
Processors
Processor : AMD FX(tm)-8150 Eight-Core Processor (4M 8T 4.21GHz, 2.2GHz IMC, 4x 2MB L2, 8MB L3)
Socket/Slot : AM2r2/AM3
Chipset
Memory Controller : AMD F15 (Orochi) CPU HT Hub 2x 1.3GHz (2.6GHz), 2x 6GB DIMM DDR3 1.33GHz 128-bit
Memory Module(s)
Memory Module : 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5)
Memory Module : Team Group Team--Elite-1333 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : LG IPS235
(1920x1080, 23.1")
(1920x1080, 23.1")
Video Adapter : 3x AMD Radeon HD 5800 Series (18CU 1440SP SM5.0 725MHz, 3GB DDR5 4GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon HD 5800 Series (1440SP 18C 725MHz, 1GB DDR5 4GHz 256-bit)
OpenCL GP Processor : AMD Radeon HD 5900 Series (1600SP 20C 725MHz, 1GB 256-bit)
Compute Shader Processor : 3x AMD Radeon HD 5800 Series (1440SP 18C 725MHz, 3GB DDR5 4GHz 256-bit)
OpenGL Processor : AMD Radeon HD 5800 Series (1440SP 18C 725MHz, 1GB DDR5 4GHz 256-bit)
Storage Devices
Samsung SSD 840 EVO 250GB (250GB, SATA600, SSD, SED) : 233GB (C:)
WDC WD30EZRX-00D8PB0 (3TB, SATA600, 3.5", 5400rpm) : 3TB (E:)
WDC WD40EZRX-00SPEB0 (4TB, SATA600, 3.5", 5400rpm) : 4TB (B:)
HL-DT-STBD-RE BH10NS30 (RAID, BD-RE, DVD+-RW, CD-RW) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS, 4kB) @ Samsung SSD 840 EVO 250GB (250GB, SATA600, SSD, SED)
PROGRAMS (E:) : 3TB (NTFS, 4kB) @ WDC WD30EZRX-00D8PB0 (3TB,
BACKUP (B:) : 4TB (NTFS, 4kB) @ WDC WD40EZRX-00SPEB0 (4TB, SATA600, 3.5", 5400rpm)
Hard Disk (C:) : 232GB (NTFS, 4kB) @ Samsung SSD 840 EVO 250GB (250GB, SATA600, SSD, SED)
Hard Disk : 450MB (NTFS, 4kB) @ Samsung SSD 840 EVO 250GB (250GB, SATA600, SSD, SED)
Optical Drive (D:) : N/A @ HL-DT-STBD-RE BH10NS30 (RAID, BD-RE, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller
LPC Legacy Controller 1 : T2 87-21
Audio Device : ASUS IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : ASUS Cypress HDMI Audio [Radeon HD 5800 Series]
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : ASUS SB700/800 SATA Controller [AHCI mode]
Disk Controller : ASUS JMB362 AHCI Controller
USB Controller 1 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 2 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 3 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 4 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 5 : ATI (AMD) SB700/800 USB OHCI2 Controller
USB Controller 6 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 7 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 8 : ASUS ASMedia XHCI Controller
FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller
SMBus/i2c Controller 1 : ATI SB800 SMBus
Printers and Faxes
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : Canon MB2300 series Printer (Colour)
Printer : Canon MB2300 series FAX (200x200)
Printer : Adobe PDF Converter (4000x4000, Colour)
Printer : Canon MB2300 series FAX (200x200, USB)
Printer : Canon MB2300 series Printer (USB, Colour)
Scanners and Cameras
Scanner : Microsoft MB2300 series _2DF26E42E232 (Scanner, USB)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 10 Professional Tablet PC Edition 10.00.10240
Platform Compliance : x64
SiSoftware Sandra
WAVE OUT
General Information
Device Name : Digital Audio (S/PDIF) (2- High
Manufacturer : Microsoft
Version : 0.00
Product ID : 65535 - 1
Specific Wave Information
Maximum Standard Sampling Bits : 16-bit
Maximum Standard Sampling Rate : 96kHz
Channels : 2
Device Capabilities
Pitch Control : No
Playback Rate Control : Yes
Synchronous Operation : No
Sample Accurate Position Information : Yes
Volume Control : Yes
Balance Control : Yes
Performance Enhancing Tips
Warning 710 : Driver may be obsolete. Check that it is the latest version.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 11-10-2015, 02:58 PM
Emcha_audio's Avatar
Windows 10 is not yet qualified for any avid products.
Manny.
#BOYCOTTTUSPRODUCTS
just not Pro tools and compatible plugins...
Old 11-15-2015, 11:52 PM
I know. I am the OP.
Just adding more info to the thread.
Fast Track Ultra not working on Yosemite even with drivers gdesign FireWire and USB Audio Interfaces (Mac) 0 01-08-2015 11:19 AM
Drivers Fast Track Ultra pour Mavericks !!! deodorant Le Forum en Français 1 01-22-2014 03:29 PM
Fast Track Ultra 8R DRIVERS 6.1.8 WIN milo_90col Third Party Interfaces 3 01-04-2014 03:18 PM
Fast Track Ultra 8R Drivers Win 7 ver. 6.1.9 DL Tanno Buchino FireWire and USB Audio Interfaces (Win) 3 07-15-2013 02:44 AM
Fast Track Ultra 8r drivers won't update bcarrigg90 General Discussion 0 12-06-2012 10:22 AM
