Old 01-17-2015, 02:18 PM
Brother Junk Brother Junk is offline
Default Beat Detective alternative use?
Hey all,
First off thanks for this forum. Coming from Logic a few years back (still use both) this place has answered so many of my questions about PT.
Beat Detective; If I have a lead track, is it possible to use beat detective, based off that track to auto locate where possible drum hits would fit best?
I've not seen it used this way, but was wondering if it was possible. Basically to take your lead track, & pretty much give you a groove template you could just fill in. I hope that makes sense.
I would essentially create edit groups with my typical drums (I track them each separately) but leave them blank. Or is BD just going to give me drum hit spots that are in line with my lead instead of the silences in the lead?
TIA
Old 01-17-2015, 08:05 PM
GregV GregV is offline
Default Re: Beat Detective alternative use?
Good question. I'm pretty sure that BD is going to have trouble "extrapolating" an appropriate groove during the spaces.
A possible work around would be to record a shaker track, or some other percussive instrument. You can play the approximate groove that you imagine while listening to the lead track. Once you record it, you can slide around any errors you may have made until you've got it feeling right.
Then use BD to create a groove template from that.
I used that trick to follow the action in a film sequence once. It worked out pretty well until they re-edited it!!
I hope that helps. Good luck
Tempo mapping Beat Detective or identify beat? grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2012 09:13 PM
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! Robbry Pro Tools M-Powered (Win) 0 02-24-2010 02:14 PM
Alternative to beat detective le stanonbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-27-2004 04:00 AM
Beat Detective alternative for LE rockwithrespect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-19-2004 06:24 PM
A Beat Detective alternative for LE users? MindDead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-27-2004 01:58 AM
