Old 11-22-2014, 08:35 PM
Julia0606 Julia0606 is offline
Default Pro tools 11 playback issue
MacBook Pro 2012
Processor: 2.3 GHz Intel Core i7
Mac OSX 10.9.5
Pro Tools 11.2.0
Memory: 8 GB 1600 MHz DDR3
I just recently encountered a problem playing back audio using Aggregate I/O. The audio plays back with high frequency clicks - probably 5-10 per second, seeming to jump between left and right. It sort of sounds like when the H/W buffer size is set too low and playback can't keep up. The problem persists when I play back from either both pro tools 10 and pro tools 11, but only occurs when the playback engine is Aggregate I/O. I usually play back through a TC interface, and it works fine through that. (I don't actually know how long this has been a problem for since I rarely use Aggregate I/O.) I've tried trashing prefs, messing with all the settings in the playback engine of both pro tools 10 and 11, and I've tried manually uninstalling and reinstalling pro tools 11. Now I'm out of ideas. Can anyone help?
Thanks!
Old 11-22-2014, 08:41 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Pro tools 11 playback issue
What's the sample rate ? If it's too high your aggregate device may not have that capability
Daniel
Old 11-22-2014, 08:50 PM
The one I am working on now is 48 kHz - well within the capabilities of the internal sound card. I've tried it with a few different sessions as well.
Macbook Pro
2.4 GHz Intel Core 2 Duo
10.8.2
M-Audio Fast Track C400
Protools 10
4 GB Ram
Old 11-22-2014, 08:51 PM
YYR123's Avatar
Strange - have you tried backing up and updating to the latest PT release? 11.2.2
Daniel
Old 11-22-2014, 08:54 PM
Yeah, I tried updating to 11.2.2, and that didn't fix it. (When I uninstalled and reinstalled I went back to 11.2.0.)
Macbook Pro
10.8.2
Protools 10
4 GB Ram
Old 11-22-2014, 09:35 PM
YYR123's Avatar
Weirder - why are you aggregating? What are you gaining?
Daniel
Old 11-22-2014, 09:58 PM
Haha.. good question... I have just always used that as the playback engine when I'm using the internal sound card because that's what I used back in the day when macbooks had separate inputs and outputs. Built-in output works just fine so I think I'll just let it be a mystery why Aggregate I/O doesn't work! Thanks!
Macbook Pro
10.8.2
Protools 10
4 GB Ram
Old 11-22-2014, 10:08 PM
YYR123's Avatar
Daniel
Old 01-17-2015, 02:24 PM
NealMiskin NealMiskin is offline
I have had the same issue. Click/pop noises on playback while using aggregate I/O. Noises, at least for me, are only on playback, though they can heard while recording are not printed to the tracks (phew!).
I don't really need to use aggregate I/O very much either, but I'm curious to know if there is a solution to this issue.
Pro Tools 10 Playback Issue thirtysixstrings macOS 2 11-23-2014 09:27 AM
Crossgrade from mpowered to pro tools 9 - Recorded songs playback issue Mike1005 Windows 1 12-07-2012 01:09 PM
MBox Mini/Pro Tools 10 playback/record issue Ewan T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-11-2011 03:54 AM
Pro Tools 9.0.5 Playback Issue PD-John macOS 2 09-14-2011 11:41 PM
Playback Issue in Pro Tools M-Powered Essential Project Alula Pro Tools SE and Essential (Win) 1 03-08-2010 07:53 PM
