Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 06-25-2002, 06:34 PM
qubesound qubesound is offline
Default SCSI vs Firewire
I'm about to purchase a external hard drive for recording. I don't know much about the differences in performance of SCSI drives vs Firewire drives. So does anyone out there recommend one over the other?
G4 733 running 9.2.2
Any help or opinions would be greatly appreciated. Thanks.
Old 06-27-2002, 06:01 AM
studiojimi's Avatar
studiojimi studiojimi is offline
Default Re: SCSI vs Firewire
i'm using 2 80 gig firewire drives
one to record the other to back up on thru usb
i hooked it straight up in the place where the system drive was and moved the system drive and velcroved it up to and above the superdvd/burner
i'm thru with scsi unless this prooves to be the wrong way to go but so far my HD III sytem has power to spare until i push the threshold to the unknown.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 07-01-2002, 10:46 PM
The Chinese The Chinese is offline
Firewire is neat. but SCSI will outperform it. It just depends on your needs. If you onl need 24 tracks w/ low edit density, then firewire will work just fine. If you need heavy edit density/high track count, then SCSI will give you what you need to a point, but usually about 40 tracks off a drive w/ serious edit density. If you need more than that, then you'll need 2 or more drives, or a Fibre system (expensive). hope this helps-
Todd A.
Old 07-02-2002, 08:24 PM
polly serial polly serial is offline
qubesound,
i work in audio post as a sfx editor.
i sometimes have all 64 tracks pumping, with insane volume, and quicktime going too.
i use a g4 867 with ide and firewire drives.
unless money is something you need to spend for tax writeoffs, i heartily suggest firewire!
but be careful, get redundant drives, as the drives get bigger, it's really the only way to back things up.
good luck.
Old 07-09-2002, 06:44 AM
studiojimi's Avatar
unless money is something you need to spend for tax writeoffs, i heartily suggest firewire! <font size="2" face="Verdana, Arial">
let's not forget the ability to put in another HD farm too with the added unused scsi slot
HD4!
CAZADOR RECORDING
Old 07-14-2002, 09:52 PM
Java Java is offline
funny, I was just wondering the same thing myself. A new aquaintance said that I could use firewire instead of the ATTO scsi method.
So I what I want to know is this...
What about Firewire raid systems? These are so cheap and that new Cremax SoHo Raid solution looks really slick. I could buy two and use one for quick backups and still have enough money left for lunch.
Is anyone using a firewire raid system and if so what have your experiences been?
Your time is appreciated.
Java
Old 07-15-2002, 01:21 PM
WheelSpoke WheelSpoke is offline
Hello,
there are advantages and disadvantages depending on your needs. SCSI is more robust because the drives can be "saved" with SCSI utilities. The technology also seems to be more stable, probably because of the long history. However, what FireWire does best is recording streaming data so it fits nicely with Pro Tools and things like Retrospect Backup, Video Capture etc...
Cheers!
Old 07-18-2002, 03:56 PM
Polaris20 Polaris20 is offline
SCSI (the fastest) may be faster right now, but there are new versions of FW on the horizon, just as USB 2.0 is out now. The latest I've heard is 1000Mb/sec is the next possible iteration.
Old 07-26-2002, 11:08 AM
He Who Cannot Be Named He Who Cannot Be Named is offline
I bought a pocket sized drive from avammo.com for using PT on my G4 laptop...I have been doing 52 tracks on it & since I dont need a power outlet for it I say FW all the way...
Old 07-30-2002, 06:53 AM
GkHz GkHz is offline
This really depends on which ProTools system you are using. For example, if you're using ProTools LE (w/M-Box, 001, or 002), then FireWire will provide enough access time at 7,200RPM. If you're using any TDM system, including HD, then you should really consider SCSI external solutions, at 10,000 or 15,000 RPM, if you want to be able to hit maximum track counts, and edit at will. Audio is seek intensive, and quite demanding on the drive, so the quality of your FireWire or SCSI external is VERY important. Thanks Todd, for your accurate advice. [img]images/icons/cool.gif[/img]
GkHz
SCSI or Firewire ewan Storage Subsystems 7 01-23-2005 12:48 AM
SCSI vs. Firewire jaygro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-29-2002 07:54 AM
scsi vs. firewire fieldtheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-10-2001 11:27 AM
Firewire to SCSI COCO Tips & Tricks 5 04-02-2001 10:41 PM
Does Masterlist support SCSI CD-R on a Orange Firewire-SCSI adapter ?? dw Pro Tools TDM Systems (Mac) 0 12-26-2000 05:05 PM
