Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
  #31
Old 07-17-2000, 11:37 AM
Steve Rosenthal Steve Rosenthal is offline
Default Re: Apdatec 39160?
1) Does the ATTO card work in older Macs (9600, PowerTower Pro)
Yes.
2) Is the Ultra160 dual channel ATTO card (the latest one) approved?
It's in test.
3) I've seen several G4's with ATTO cards that refuse to boot if hard drives with older FWB drivers are placed on the SCSI chain. The ATTO card seems really touchy about this. Polaris mentions running current firmware on hard drives - so my question is: Is the ATTO card picky about hard drive firmware, or just picky about the software driver placed on the hard drive by the formatting software?
The only FWB/ATTO incompatibilty I'm aware of was an FWB bug that conflicted with ATTO firmware 1.2 or greater. This FWB bug was fixed in version 3.0, I believe.
4) If I put LVD and/or Ultra160 drives on an Adaptec 3940U2W, what will happen? Should it work?
Well, first off there is no "3940U2W." The 3940UW is a single-ended, dual-channel card. Perhaps you mean the 2940U2W, which is single-channel, LVD card. Nevertheless, SCSI is backwards compatible, so the drives should work on either card. You will be limited by the weakest link in the chain between the card and the drives. Example: A 160 drive on the 3940UW will only be able to operate as a single-ended device with a maximum burst rate of 40MB/sec. It will also be limited to the allowable cable lengths of single-ended SCSI. On a 2940U2W, the drive will be limited to a maximum burst rate of 80MB/sec, but the cable length will be the same as a 160 card -- 12 meters total -- since both are LVD.
--Steve Rosenthal, Digidesign ETS
  #32
Old 08-25-2000, 05:58 PM
loopengine loopengine is offline
what is the latest on the 160 testings?
  #33
Old 08-30-2000, 01:07 PM
MARVINBASS MARVINBASS is offline
Steve how about an update!!!
My System is:
Mac Pro 2.8GHz Quad-Core Mid 2010 MC250LL/A
16GB RAM
1- HDX
1 - Apogee Symphony Mk1 8x8
1 - HD 16x16 Interface
MOTU MTP/AV
MARVINBASS Digital Audio
Pro Tools and Mac Consulting
Woodland Hills, CA.
  #34
Old 09-01-2000, 03:35 AM
tombrewer tombrewer is offline
Polaris,
"The only problem I've encountered is the two inits at bootup with more than one drive connected which I believe to be a problem even with the ATTO"
Yes - this was also a problem for the ATTO, but it was solved simply by upgrading to 5.0.1. With 5.0, the explanation was too many USB Devices & Drives - unbelievable.
Thomas Brewer
Adaptec 39160 MARVINBASS Storage Subsystems 4 01-17-2006 06:45 PM
Adaptec 39160 revisited Polaris Pro Tools TDM Systems (Mac) 3 05-23-2001 06:28 AM
New G4 and Adaptec 39160. Will it work now? Bokir General Discussion 3 03-01-2001 09:28 PM
Will the Adaptec 39160 work with LE? blanketsick Pro Tools TDM Systems (Mac) 0 08-13-2000 10:00 PM
powerdomain 39160 ultra 160/m thefly Storage Subsystems 1 11-14-1999 01:05 PM
