Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 02-07-2010, 12:58 PM
sirprotools sirprotools is offline
Default superior drummer 2 pro tools LE 7.4 track routing: help!
For the life of me I cannot get my output tracks from SD2 onto individual instrument audio tracks in PT LE 7.4. I have a midi track with note info routed to SD2 on an audio track, which I can monitor. Problem is, I am trying to route each instrument, eg. bass drum, snare, etc to a separate track and it is not working.
First, when I go to monitor SD with an additional PT audio or aux track, I can see an input under plugins for "superior drummer multi out - superior drum monitor -- insert A" and then and arrow and a drop down with "S2 to S16". Ok, good so far, except the bass drums are on S1 -- output 1 in SD. Whatever track I select, S2, S3, etc, no matter if I have an instrument assigned to that output in SD, it doesn't register in the PT track on which it is selected.
I am sure I am doing something very basic incorrectly, but I have read the entire SD manual (and a good bit of the PT manual), and I just don't see it.
Any help greatly appreciated.
Seth
Old 02-07-2010, 06:42 PM
nst7 nst7 is offline
Default Re: superior drummer 2 pro tools LE 7.4 track routing: help!
The easiest way is to set up a stereo instrument track and insert SD on it. Then set up some mono aux tracks, and a couple of stereo aux tracks for the overheads and room mics. Then you should be able to route SD's outputs to whichever aux tracks you want. And of course set the input of the aux tracks to receive whichever SD output you want. This will allow you to process the tracks individually.
If you want to record the individual instruments as audio, just set up audio tracks instead of aux tracks, the same way, and record arm them, etc.
There's no need to set up any midi tracks.
Problem : my MIDI track is not read by Superior Drummer. gregsim The Drum Room 5 07-31-2016 03:20 PM
Pro Tools 11 Not Reading Superior Drummer BCoop Virtual Instruments 5 12-22-2013 10:15 PM
Superior drummer 64 bit in pro tools 9 Raoul23 The Drum Room 3 07-19-2011 11:00 PM
SUPERIOR DRUMMER 2.0 in PRO TOOLS 9 Leonidas666 macOS 2 05-25-2011 01:40 PM
Superior Drummer + Pro Tools Mike1983 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-17-2009 04:56 PM
