Old 10-15-2009, 01:48 AM
onosai onosai is offline
Default help!? "the installer could not write the receipt for "plug-in updates"??
i recently bought pro tools m box2 mini and it was going perfectly until i stupidly thought that by uninstalling it i would free up more memory on my mac os x. i did not do a safe uninstall but did a clean uninstall. then when installing pro tools again it stops halfway through installment and says "the installer could not write the receipt for "plug-in updates".
im guessing when i did the clean uninstallment it wiped certain plug-ins and system files needed for the compatibility with some Avid products?
do you know what i should do?
i live in NZ and tried ringing a whole lot of people but NZdrs and music software just dont go
thanks so much
Old 10-15-2009, 02:59 AM
max howarth max howarth is offline
Default Re: help!? "the installer could not write the receipt for "plug-in updates"??
it sounds like a permissions issue. when you install an app or plugin a receipt file is created here:
hd>library>receipts
if the installer hasn't got write access to that folder the installation might well fail.
try repairing disk permissions using the disk utility app.
best wishes
max
www.redfacilities.com
2 x 3.3 6core mac pro | 12gb ram | mac os 10.7.3 | nu5.5 | rme multiset/audiolink96 | 3 x 19" flat panels | decklink xt | waves8 | altiverb7
Old 10-15-2009, 08:32 PM
thanks so much max for answering, tried repairing it but no luck, will try taking my comp in to a specialist, thanks once again, hello from nz
"Unable to write receipt for plug in updates" Freddyroc747 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-29-2012 06:20 PM
Pro Tools 9.0 "Updater" or "Full Installer"? jacknprewitt Pro Tools 9 7 12-24-2010 08:47 AM
The installer could not write the receipt for "plug-in updates" Dedelman2005 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-22-2009 08:53 AM
Installation Problems, "could not write the receipt" thegordian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-22-2009 04:49 AM
Installer can't "write the receipt"???? [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-26-2008 10:39 AM
