Old 09-08-2009, 04:07 PM
Digitopian Digitopian is offline
Default What would normal disk usage considered to be in the usage window?
After installing 8.0.1 I began working on a session that was atypical for me in many ways. It was my first time using strike as the drum track, first time using multiple instances of eleven, and first time in a while doing a session at 88.2khz. Also I believe it was the first time that i chose to record at 64 hardware buffer setting, foregoing recording in low latency mode. After slapping on some plugs to get a quick idea of how it things might sound mixed I inevitably ran into a cpu error. Not surprising considering this was a session of firsts.
At this point I decided to continue the session with the usage window up to get an idea of how various things were effecting the cpu usage and noticed that cpu usage seemed a bit high(although I understand why this is) but also I noticed that the disk usage was higher than I had ever seen it. Normally I have never seen it above 10% but i should state that I generally don't work with the usage window open as i generally don't really run into many usage type issues.
This peaked my curiosity and i decided to open up some session that were fully mixed and edited as well as a few sessions that have a pretty high track count. What i noticed was that on many of my sessions (particularly the ones with high track count) the disk usage was showing as high as something like 27% maybe more. So now I am even more curious. Is this normal? Have I been using Protools for ten years without noticing this, or is this a sign of something else. The drive that I'm recording to only has about 40gig out of 500 used. Not sure if that matters but I figured I'd throw that out there.
Sorry to be so long winded but i couldn't really think of a concise way of asking the question in the title of the thread. So what do my fellow duc'ers think?
Mac Pro Quad-core 2.6, 5 gig ocz ram,1Tb hd internal, OSX 10.5.7, 2 internal Audio HD,lacie 500 gig external fw 800 drive
Digi 003 rack, PT le 9.0.1, Mac Book Pro 2.4ghz I5, 4 gig ram, PT 9.0.2, Apogee duet
Waves gold, and ssl plugins /Reason4 /miroslav philharmonik /stylus rmx /Melodyne /T-racks3 deluxe / Strike /Massey compressor, DTM /Sound Toys /blah blah etc.
UA610 pre's / Chameleon Labs 7602mkII pre's / Chameleon labs 7802 stereo opto tube compressor/ Mackie hr824 monitors
Old 09-08-2009, 08:48 PM
Default Re: What would normal disk usage considered to be in the usage window?
Long Story short, I took a look at things tonight with a clear head and it seems that a majority of my sessions do show very little disk usage. A Session like the one that comes with multi-platinum mixing with fifty-ish tracks shows as just under 30% disk usage. Don't know why It tripped me out. Nothing to see here folks, lol! I'm gonna go bury my head in the sand now.
DTS you can definitely delete this thread!
Old 09-08-2009, 09:04 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Digitopian piece u should see if Tamara is home
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 09-08-2009, 09:14 PM
LOL, I know I know.....it was a long night last night. What can I say...I'm just waiting for something to go wrong i guess.
Old 09-08-2009, 09:25 PM
Well thatz understandable... really makes it feel much better when things Don't go wrong hunh & when they do, u can say I knew that was gonna happen instead of AAHHHHHHH, WHAT HAPPENED: HELP:HELP: MY TUESDAY CAME BEFORE MY MONDAY!!! CAN U HELP ME DIGI BETTER FIX THIS ON SUNDAY!!!!
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 09-08-2009, 09:31 PM
Key, whatever you do don't look at my thread in the virtual instruments section, lol. It was posted about the same time as this one and while i do believe there is a tiny bit of merit to it, I would say that for the most part it's just more paranoia. You hang out here long enough with everyone and their bugs and dooms day scenarios and it becomes contagious!
Old 09-08-2009, 09:36 PM
OK now u know u shouldn't have told me NOT to look @ it
& yeah ur rite about some getting paranoid after seeing other peeps problems... I'm one of the few that doesn't let that get me though; My system(s) are usually really stable[knocking on wood on'eim]
I'll check back with ya though.....in ur other thread
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 09-08-2009, 09:50 PM
I'm actually in the same boat. I never had the dreaded playback issue when I upgraded to pro tools 8, or any other significant issues. I generally run a pretty tight ship with my rig and do all the common sense things but this past week and a half I have had more issues than i care to go into. Ironically they were all hardware related. I learned some valuable lessons regarding a certain company and their QC or lack there of and my second favorite Recording amp decided to get all cranky on me so I guess the paranoia has been building for a little while.
Anyway check that post if you haven't already! I'm curious to see what you think.
How much memory usage does your PT take up on normal launch ? hwill2008 Pro Tools 9 2 04-27-2011 07:11 PM
system usage window... is this normal...? drmmrboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-06-2007 03:17 PM
Help understanding CPU Usage, RAM, Disk Usage... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-03-2006 07:41 PM
Anyone use SiS chipset? Normal CPU usage? illfi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-15-2002 08:22 AM
why is my System usage..and disk space window are grey out ?? vudoo Pro Tools TDM Systems (Mac) 0 08-27-2001 01:04 AM
