Old 04-05-2009, 07:21 AM
redchair redchair is offline
Default template headphone send for 003 PTLE8?
Not sure what and how to use the new headphone send that are factory set up with the new templates that come with PT8,,,is thier a link to find out about this?, i am using digi 003 control to plug in my headphones....
Redchair Recordings
Old 04-05-2009, 10:45 AM
TOM@METRO's Avatar
Default Re: template headphone send for 003 PTLE8?
Hi Redchair, could you elaborate on your question?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-05-2009, 12:01 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Honestly u don't need that unless ur tracking multiple people @ once & u need separate headphones mixes...
If thatz the case, u just go out the ur console,maybe 3-4 >into a headphone amp or mixer & set that headphone track output ur referring to to 3-4... there's a couple of ways to do that but thatz basically what that is...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 04-06-2009, 01:32 AM
TOM@METRO's Avatar
As important as it is to have the ability to send separate headphone mixes, Its only once in a blue moon that someone actually requests it around here. A good blended mix usually works for the whole band, the occasional exception is a live vocalist.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 04-06-2009, 05:02 AM
thanks for the help,,,,that all said,,,is there a way to reset the factory templates so when i go to use them the headphone send is not there...or should i just make the changes per session and "save template"
Redchair Recordings
Old 04-06-2009, 09:08 AM
Yeah just make changes & save ur own...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 05-31-2009, 10:43 AM
fifthletter fifthletter is offline
if i were to connect my head phone mixer into the 002 i loose my talkback
Old 05-31-2009, 12:25 PM
rqstudio rqstudio is offline
What, are you using some sort of digital mixer fithletter? If so, you should be able to bus your talkback to all outputs.
But I wasn't aware of a talkback template, where is this located? I'd like to check it out.
Old 05-31-2009, 06:03 PM
My setup feeds the main mix to the headphone amp(HA4700) and I rarely need more than that. If I do, I have 4 outputs of the 003 patched into each of the 4 sections of the headphone amp so 4 players can have "more me". My space is not big enough for more than that anyway. Something to keep in mind about aux sends feeding headphones. If they are set to Post-fader, you can't solo anything as it will interrupt the headphone feeds. If you go Pre-fader, when you mute a track, it is NOT muted in the phones(this can cause some nasty results if you unplug a phantom powered mic while someone has phones on; you think its muted but the player gets an ear dart). I vote for DIGI to change this in the next release. MUTE should mute EVERYTHING on a given track. Where's that feature request link?
Old 05-31-2009, 07:02 PM
Or while you're at it and adjustable dim.
How to send my mains mix to a headphone amp? Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-13-2014 11:37 PM
Headphone cue send setup in Pro Tools... thoughts? keevhren Pro Tools TDM Systems (Mac) 1 05-28-2011 04:36 PM
control 24 studio headphone send issues tom devilution ICON & C|24 2 10-17-2007 06:44 PM
setting up a headphone send Andrew Red 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-16-2006 01:03 PM
Can anyone send me a TC template? Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-26-2002 04:18 AM
