Old 05-04-2008, 06:07 PM
M8kinMoves M8kinMoves is offline
Default Quantizing Metal Drums
Is there anyone out there who has any tips for quantizing fast metal drums with lots of double kick. I have been using beat detective, but it has not come out sounding that great. I have also tried some other manual methods with mixed results as well. Any tips would be appreciated.
Old 05-04-2008, 07:21 PM
your one guy your one guy is offline
Default Re: Quantizing Metal Drums
get a better drummer???
Old 05-04-2008, 07:57 PM
French links French links is offline
If you have 7.4 use Elastic Audio (there is a video about drums on the website).
If not...Redo the performance....
Protools is very powerful okay but it won't make all the work for you changing a frog into princess.It just helps tightening a bit so it means the performance must be as perfect as possible...
Old 05-06-2008, 11:37 AM
TheBaron TheBaron is offline
You guys are harsh!
I'm pretty clueless in protools and I wish I could help. I've got to say, I've had some weird things happen with groove quantize myself. Even when I experimented with a simple, slow beat and a few quicker notes layered in. Can't explain it but I've heard some wacky things happen to beats that were absolutely on time...so I'll be eagerly awaiting some constructive comments on this post.
Old 05-07-2008, 12:51 AM
constructive? good luck!...
Old 05-07-2008, 10:10 AM
ondruspat ondruspat is offline
A friend of mine who specializes in metal uses beat detective all the time. He told me to take the song in small sections (one or two bars at a time) and process them. Even then he said he always manually checked the edits. To him it was time comsuming but the results were worth it.
But after he flew up to my place last week and checked out 7.4 he's updating ASAP. Elastic audio seems the way to go now. EA process your tracks, switch their timebase to ticks instead of samples, and quantize away (assuming that you used a click or have made a tempo map). I Youtubed a whole bunch of EA videos, there is plenty of instruction out there for you.
Btw: he also swears by Sound Replacer for modern metal drums...
"Sometimes having limits keeps you sane"- Albee1952
Old 05-07-2008, 10:30 AM
audiogeekzine audiogeekzine is offline
work on small sections, 8 bars max.
Do you have the resolution set to 32nd notes? Analyze with sub-beats?
Use collection mode if you've got it for the best results.
Analyze the kick track, add to collection, analyze the snare track, add unique to collection, select all your drum tracks, separate regions, region conform.
Do the whole song, then apply region smoothing and crossfades.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Metal Foundry or Evil Drums NuBus Virtual Instruments 11 04-06-2010 03:46 PM
Quantizing Metal Drums M8kinMoves Tips & Tricks 6 04-25-2009 11:55 PM
Quantizing Drums with 7.4? steveooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-01-2008 02:44 PM
Quantizing Drums Angus202 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-10-2005 07:08 AM
OT- DFH or BDF drums for pop/rock (not metal) keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 06-17-2004 01:20 PM
