96 I/O and ADAT
It looks to me like you can add an extra 8 in and 8 out to this card by using an ADAT preamp. Then you have the 8 analog I/O plus the ADAT I/O available simultaneously. Is this correct or am I just hoping.
I am about to purchase the C/24 TDM bundle and was looking to expand by just 8 more I/O. |
Re: 96 I/O and ADAT
Below is from the manual, available in the both the support and product sections of the digi website.. AS it states, you are limited to 48k for 8 channels. I have a presonus digimax FS.. very versatile, as long as i only go 48k. The DAC allows me 8 analog outs (great for cues).. and the 8 analog ins are ok for "non critical" inputs. The pre's are marginal, but functional. For the money it is very practical. I have also a Octapre.. not as versatile, and creates a LOT of heat. SB
The Optical ports accept up to eight channels of Optical (ADAT) input and output, or two channels (stereo) optical S/PDIF input and output. Optical (ADAT) mode supports sample rates up to 48 kHz. In TOS-Link mode, the 96 I/O supports two-channel Optical input and output at sample rates up to 96 kHz. |
Re: 96 I/O and ADAT
Thats correct. I use an Alesis AI3, which gives me 8 more inputs and outputs. Its cheap, but its only ins and outs, not a pre.
I use it for FX inserts. gunnar |
Ever had a Yamaha ADAT card go bad? 01V's ADAT won't work. | scoobydoo | Pro Tools TDM Systems (Mac) | 2 | 03-02-2008 10:45 AM |
ADAT to PTMixPlus via ADAT bridge...digital pops? | Phattlippz | Digidesign Hardware & Software | 2 | 05-28-2006 05:13 PM |
ADAT IN works fine - but dont get Output via ADAT | kaladun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-08-2005 04:15 PM |
Digi001 ADAT, Alesis ADAT Edit and Fostex VM00 | phobia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-24-2001 08:57 AM |
cable lenght (fiberoptics) adat to adat bridge | olek | Pro Tools TDM Systems (Mac) | 10 | 02-21-2000 07:47 PM |
