Old 01-24-2007, 12:54 AM
mouse hole mouse hole is offline
Default cpu vs. disk usage
i really should understand this by now but i am still unsure about the difference between the cpu usage and the disk usage in the system usage window. are these two totally different issues? is the cpu usage related to your processor speed and RAM and the disk usage related to your hard drive's ability to get the necessary data into the RAM and processor? is my OS, PT and all the rtas plug-ins/virtual instruments i am using even accessing the hard disk that much or is it all just RAM and processor related? i ask becuase my cpu usage is always maxed out and my disk usage is barely even registering. does this mean that accessing the hard drive is not an issue and the real issue is just that my processor is too slow and i need more ram?
ps. my ram is already maxed out and i can't afford a better processor. the only thing i could do is get another hard drive or a faster hard drive but i am thinking that this won't solve the problem...
if someone could shed some light i would appreciate it.
1.8 ghz
1.5 gig of ram
7200 rpm internal
7200 rpm firewire 400
Old 01-24-2007, 10:47 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: cpu vs. disk usage
You are on the right track. Usually processing power runs out before disk access.
As you increase track count, the cpu and disk usage will increase. As you add plugs, only the CPU will increase. If you want more plugs or instruments, you will need a faster computer or Digi needs to improve the software!
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-25-2007, 05:08 AM
Gothboy's Avatar
Gothboy Gothboy is offline
I was going to ask how many tracks you have going when you have this problem?
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Ableton Live 9/Presonus Studio 3
I no longer use Pro Tools and just as happy!
Drive too slow errors (while disk usage at 0%) Frank Kruse Pro Tools 11 10 09-24-2013 11:19 PM
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Disk usage discussion solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-27-2008 12:48 PM
Heavy Disk Usage seems strange? fman Pro Tools TDM Systems (Mac) 2 07-17-2007 09:01 PM
Help understanding CPU Usage, RAM, Disk Usage... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-03-2006 07:41 PM
