Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 03-08-2005, 06:05 AM
jimbreese jimbreese is offline
Default Audio Record Volume
Hello.
I am using a lacie 250GB Firewire 400 External HD. When saving a new project to this drive, Pro Tools tells me "Session must be on an audio record volume"
Within workspace I cannot change the A and V collums to Record enabled. Pro Tools tells me "Lacie cannot be designated as an audio record volume as it is not a valid audio volume."
The drive is 7200rpm and supports the oxford 911 chipset.
Am I doing something incorrect or will this drive not work with Pro Tools.
Please help,
Regards,
Jim Breese.
Old 03-12-2005, 10:04 AM
jamaicadave jamaicadave is offline
Default Re: Audio Record Volume
yo blood,
i have the same prob. and have been trying to solve it for a while. ihave tried re -formatting the drive to HFS+ formatt but i can't. it says something about it can't delete the partition map.
i think its because the drive is formatted in the wrong format. it needs to be in HFS+, i just can't seem to format mine.
check the lacie website too. typee in format, on the FAQ page,
Old 03-19-2005, 08:14 AM
Kuleone Kuleone is offline
What system are you using Mac or PC? If PC what OS are you running?
Old 03-19-2005, 08:48 AM
I'm running a Mac Powerbook OSX 10.3.4.
Any ideas Kule?
Old 03-20-2005, 02:54 PM
If you have access to a pc, try formatting the drive under the PC OS. Please note, if your using XP make sure you format the drive using basic file system not dynamic file system. Let me know what happens.
Old 03-22-2005, 08:27 AM
mistersample mistersample is offline
Hello,
I am having the same problem. From what I understand the computer does not agree with the Firmware number of the Ext. drive you are using. I recently had a Internet Mac guy come to my place set me in the whole house and updated some software. Well ever since, this Audio Record Volume has been a problem. If you hear anything please keep me posted as well as I will. I am on the hunt.
good luck
Old 03-22-2005, 11:30 AM
hey yo whats up...
i got my hard drive work ing, and its doing its thing how its supposed to.
i still am not sure what went wrong tho.
i had formatted my drive on another mac g5. u should try doing that if u have access to another mac that might can format the drive for you. in disk utilities, use mac os extended. and not the exteneded journaled.
if u were haveing the same problem as me , this shhould sort u out.
let me know if u solve the problem and if this actually helped u solve it.
it was baffleing me. so may be u can send me some insight
Old 04-14-2005, 10:19 AM
DigiTechSupt's Avatar
In Pro Tools, go to the Windows menu and select 'Show Workspace'. In the Workspace window you will see a list of your drives on the left and to the right of each drive will be an 'A'(for Audio) and a 'V'(for Video) column. Under the 'A' column next to your drive it will probably have a 'T'(for Transfer) or 'P'(for Playback) - click on the 'T' or 'P' and, from the drop down list, choose 'Record'.
You should now be able to open, play and record in your session as normal.
Avid Audio Tech Support
Support FAQ
Old 05-24-2005, 04:09 PM
pilau pilau is offline
But when I attempt to change the designation of either drive to Record OR Playback, I get:
"[Volume]" cannot be designated as an Audio Record|Playback volume because it is not a valid audio volume.
Both volumes have been reformatted and restored from backups recently. The system volume is HFS+ Journalled, the external FW volume is HFS+, NOT journalled.
Just what constitutes a valid audio volume?
Old 05-26-2005, 11:57 AM
pilau - Did you use the OSX Disk Utility to format the drive?
If you did, please try trashing Pro Tools preferences and database files, restart and try again.
Support FAQ
cannot be designated as an Audio Record volume because it is not a valid audio volume Gav_Russell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-15-2016 03:52 PM
Cannot be designated as an Audio Record Volume because it is not a valid Audio Volume soloavenger macOS 7 02-15-2016 03:49 PM
Session must be on an audio record volume if permmited set the volumes to R record lionandthemouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2013 01:48 PM
hd cannot be designated as an audio record volume because it is not a valid audio wapeddell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 04-12-2010 12:05 PM
cannot be as an audio record volume because it is formatted as a FAT volume rtm Pro Tools TDM Systems (Win) 3 12-18-2008 09:52 AM
