Old 07-28-2018, 07:52 PM
tangoportland tangoportland is offline
Default Pro Tools 12 No Playback or Record
Hello PT Community....PT 12.4 was working but not now.
When I have the focusrite 2i2 plugged in it will not playback a previosly recorded session. When I record enable a track PT quits and shuts down.
When I have the FR unplugged from my computer the session playsback.
Is it a windows playback setting or i/o setting in PT?
Usually it works fine.
I tried making a new session and same problem.
Thanks
Microsoft Windows 7 Ultimate 6.01.7601
< Processor >
Manufacturer: Intel
Model: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
< Logical Storage Devices >
System Reserved (E:): 100MB (NTFS) @ WDC WD5002AALX-00J37A0
(500.1GB, SATA600, 3.5", 7200rpm, 32MB Cache)
New Volume (C:): 168GB (NTFS) @ INTEL SSDSC2BW180A3H (180GB,
SATA600, 2.5", SSD)
WD HD (F:): 466GB (NTFS) @ WDC WD5002AALX-00J37A0
Old 07-28-2018, 08:15 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Pro Tools 12 No Playback or Record
Hi i have a FR audio card and they are very "picky" at fisrt . Please unistall all the current drivers and reinstall the lastest one . Also while launching PT after this press and hold the N key to bring the playback setup screen and select the correct playback device .
Avid Carbon Interface
Protools Ultimate
Old 07-29-2018, 05:27 AM
I tried those two approaches...
I am getting this error message.
The playback engine is set to: Focusrite USB ASIO.
Pro Tools could not initialize the Focusrite USB ASIO.
Please make sure that the device has been configured
correctly.
Thanks
Old 07-29-2018, 09:03 AM
The Weed's Avatar
The Weed The Weed is offline
Make sure the 2i2 is NOT the default for Windows sounds/audio in Control Panel>Sounds, make your onboard soundcard the default. This may or may not be the issue, but it is necessary.
And run Pro Tools as Administrator.
Have you done all the Avid recommended optimizations?
FYI, Focusrite's Windows drivers can be hit and miss.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-01-2018, 10:52 AM
jeam25's Avatar
Agreed !
Did you resolve it ?
Protools Ultimate
Pro Tools SE won't playback or record clifrodamus Pro Tools SE and Essential (Mac) 1 09-22-2012 11:20 PM
Can not record in Pro Tools 8. EXTREMELY low mic playback J.Lloyd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2010 10:13 PM
Can not record in Pro Tools 8. EXTREMELY low mic playback J.Lloyd Pro Tools TDM Systems (Win) 1 10-30-2010 06:51 AM
Mbox 2 w/ Pro Tools 8, clicks and pops during record and playback ssiimm85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-27-2010 05:11 PM
pro-tools m-powered 6.8 playback and record stops! aldaer Pro Tools M-Powered (Mac) 1 03-22-2006 02:00 PM
