Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 02-17-2018, 09:05 AM
robdbirch's Avatar
robdbirch robdbirch is offline
Default MacOS How to Stop Application Manager from Automatically Starting
Most well written and user friendly MacOS applications allow users to prevent programs from starting at either system startup or login. This is usually easily accomplished by selecting an option in the application's preferences panel or the removing the login item from the "User & Groups" login items panel.
Manually quitting after every login or system start-up is how a lousy program allows users to do it.
So, how does a user permanently prevent the "Pro Tools First Application Manager" from automatically starting?
Thanks in advance
Old 02-17-2018, 09:55 AM
BScout BScout is offline
Default Re: MacOS How to Stop Application Manager from Automatically Starting
Find the app and change its name.
Old 02-17-2018, 10:12 AM
robdbirch's Avatar
Thanks @BScout for the reply.
Amusing hack, not an acceptable resolution for a "Pro XXXX" application or any MacOS application solution, though possibly acceptable for WindowsOS.
Old 02-17-2018, 10:58 AM
zoff zoff is offline
Why not. Its the easiest way to do it on a mac.
macOS High Mojave 10.14.2
2.8 GHz Intel Core i7 MacBook Pro Retina, 16 GB RAM
Pro Tools 2018.12
Apogee Duet (Firewire)
Old 02-18-2018, 08:19 AM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
Don’t know about PT First, but with PT (full version) and PT HD, I go to the Applications folder (Mac) open the Avid folder, find Application Manager and drag it to the trash. If this isn’t possible with PT First, then it’s probably because Avid wants to spam you into getting the full version. Seems fair, as First is free.
Edward
Old 02-18-2018, 08:43 AM
DetroitT's Avatar
DetroitT DetroitT is offline
"Avid Uninstallers"
Next version install put it back so you can sync.....
Uninstall ant end of install..
Work and repeat as needed.
(Help us Help You)<<<click here
Testing:All APSF but Working Audio on HFS+
Pro Tools U-2019.5 MacOS 10.14.5
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire 7950 MacEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
Surround-music-design-creation.
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 02-18-2018, 09:19 AM
robdbirch's Avatar
Thanks, yes it there in PFT, too. I'll keep that option in mind.
Thanks again.
Old 02-18-2018, 09:20 AM
robdbirch's Avatar
Originally Posted by DetroitT View Post
"Avid Uninstallers"
Nice tip, thanks.
Old 04-04-2018, 11:27 AM
robdbirch's Avatar
I think this should work. Use at your own risk.
Open the terminal or use the finder:
From the terminal:
$ rm -i /Library/LaunchDaemons/com.avid.bsd.shoetoolv120.plist
$ rm -i /Library/LaunchAgents/com.avid.ApplicationManager.plist
$ rm -i /Library/LaunchDaemons/com.avid.hub.service.plist
$ rm -i /Library/LaunchDaemons/com.avid.transport.client.plist
Application Manager is unable to connect to Avid Servers on macOS Sierra JeffRadfordMusic macOS 9 08-25-2016 06:22 PM
stop Application Manager frcjt Pro Tools 12 2 02-29-2016 07:56 PM
Stop Pro Tools from automatically matching volume automation? Soundburst Post - Surround - Video 3 06-26-2014 10:36 AM
How do I get ProTools to stop a track automatically? ACE IT UP Pro Tools 10 4 09-12-2012 01:30 PM
