Old 04-03-2017, 12:56 PM
skiffle skiffle is offline
Default EQing harmony vocals
I'm having a problem with some vocals, i have a stereo track with acoustic guitar, mandolin, and two male voices singing in close old time country harmony's, the problem is the higher harmony vocal is a bit louder than the lower harmony vocal.
Doe's anybody have any eq and or compression advice etc?
It would be greatly appreciated !
I'm using PT9 with Macbook pro...
skiffle
Old 04-03-2017, 01:30 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: EQing harmony vocals
Multi band compression and sweep for the freq you want to tame.
That being said it is a workaround and not the best way to remedy the problem.
Anyway there might be more than one way but that's were I would start.
Daniel
Old 04-03-2017, 02:18 PM
You might try Soundradix's eq surfer. Watch the protools expert vid about it, then have a go with the demo
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools HD 12.8.3 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 04-03-2017, 02:30 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
So, this is one stereo track? How are the elements panned?
Old 04-03-2017, 03:05 PM
Thanks guys, i'll give it a try!
Ben, i sucked the tune off of a cassette onto two mono tracks originally, after doing some basic editing i bounce them to disc through a Kramer master tape on a stereo maser fader, i then imported the track back in to the project as a stereo track panned hard let and right!
Thanks again!
skiffle
Old 04-03-2017, 03:11 PM
I meant if the two vocals were a bit left and a bit to the right, you would have more options.
Old 04-03-2017, 03:49 PM
Unfortunately not Ben, it was originally recorded with both vocals and guitar on one mic, and the mando through another mic on another track, both panned up the middle on an old tascam porta studio, the high harmony guy was a bit to close to the mic!
Cheers!
Old 04-03-2017, 07:05 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Would Melodyne help with something like this? I think some versions of Melodyne can extract individual voices so you can manipulate them, separately.
Pro Tools 2018.4 | OS X High Sierra | RME
Old 04-03-2017, 07:27 PM
Its worth a try, but don't expect a miracle(although Melodyne delivers that quite often). If you get lucky, and the part you want to lower is NOT on the same note as the acoustic, it may work, but that's going to be a crapshoot
Old 04-04-2017, 01:10 AM
Stephen Bond's Avatar
Originally Posted by skiffle View Post
skiffle
The high harmony will always cut though more than the low ones in the same way that a high hat seems much louder than a bass drum if they are showing the same on the meters.
EQ and compress just add to taste. Probably impossible to say much more without hearing the tracks.
Stephen
Save an additional 10% off any purchase at Waves!
https://www.waves.com/r/9zsnwd
EQing Vocals - Venue EQ or Plug-in EQ Tigerspill VENUE Live Sound Systems 3 10-17-2013 08:13 AM
Eqing Fastermouse General Discussion 1 11-05-2009 03:11 PM
help with EQing Robbery3 Tips & Tricks 9 05-16-2007 11:42 AM
What are some techniques for mixing/EQing vocals MusicalWonder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-19-2005 07:54 AM
Is EQing the best way? slrobinson83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2004 06:55 AM
