Digitest
I have downloaded the latest version of Digitest from the Digi site. My system works perfectly, but I would still like to periodically run Digitest. Whenever I launch it, it gives me error #4 on the last DSP Farm and first Disk I/O.
Here is my rig: PT3 - 4.3.2 Beige G3/300 Bit 3 7 slot chassis From left to right in the expansion chassis DSP Farm II DSP Farm II DSP Farm II Backplane DSP Farm Disk I/O w/ 888 Disk I/O w/ 888 Disk I/O w/ 888 Like I said, everything works perfectly. Is this a known bug OR am I doing something wrong? |
Re: Digitest
I wouldn't worry about it, often times it is necessary to take Digitest results "with a grain of salt". The true tell tale sign is how Pro Tools is running on your system. Another way to test the integrity of your farms is to create a session and load up a bunch of plugins. Using DSP allocator keep an eye on which plugins load in on what chips and then go "exercise" those plugins while playing back audio through them. If there is a problem with the chip, you will most likely see some "issues" quickly. If the plugin works as it should then ignore Digitest. Jon Connolly Digidesign Product Specialist P.S. Don't tell the programmers I bagged on Digitest on the DUC, OK? |
Re: Digitest
Jon,
Thanks for the honest answer! I'm not going to worry about it since everything is 100%. Don't worry, I won't tell anybody. Jim |
Where can I get Digitest? | heybluez | Pro Tools TDM Systems (Mac) | 2 | 05-13-2007 12:16 PM |
digitest on g5 | mixer | Pro Tools TDM Systems (Mac) | 0 | 01-20-2004 06:37 AM |
Digitest | bounce88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-09-2002 08:56 AM |
DigiTest | nickair | Pro Tools TDM Systems (Mac) | 0 | 04-13-2000 08:10 AM |
Bug in DigiTest 2.5.1a1 | Oliver M | General Discussion | 0 | 06-23-1998 08:00 AM |
