Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 07-07-2020, 06:27 PM
Default Re: One or more licenses to surrender cannot be found in your account
Originally Posted by TomR View Post
I'm currently running MacOS Catalina 10.15.5
There is no way Pro Tools 11 or 12 will run on Catalina.
Old 07-07-2020, 07:57 PM
TomR TomR is offline
Really? The table I have attached says it should be able to install and launch...
File Type: jpg Screen Shot 2020-06-21 at 3.37.07 pm.jpg (28.5 KB, 0 views)
Old 07-07-2020, 08:45 PM
The official compatibility tables are here https://avid.secure.force.com/pkb/ar...tibility-Chart And enough stuff is breaking at just about every macOS release.
Wherever you are looking at sure is pretty with all those colors. But none of that screenshot you gave is talking about **Pro Tools 12**. 2019.12 is NOT Pro Tools 12. You need a current license or subscription to run Pro Tools on Catalina and should likely be looking at running 2020.5. Or you need to downgrade from Catalina *if* your Mac can accept an older OS.
Old 07-08-2020, 01:55 AM
Originally Posted by DigiTechSupt View Post
You might be running on an unsupported OS version. May we know what OS version you're currently running on?
Thanks,
Tope
I'm running MacOS Catalina 10.15.5 on a MacBookPro14,3 Quad-Core Intel Core i7 2.8 GHz. Looks like I have to upgrade to Pro Tools 2020.5...or downgrade my OS?
Old 07-08-2020, 03:19 AM
JFreak's Avatar
JFreak JFreak is online now
You need to upgrade to current version if you want to be running Catalina. You will need 2019.12 or later for that. I am running 2020.5 here.
Janne
  #16
Old 07-08-2020, 09:41 AM
You have to pay attention to compatibility, but I am guessing the ".12" thing was confusing.
And for that MBP, you could downgrade the OS to 10.12.5 https://everymac.com/systems/apple/m...bar-specs.html
Which again from the Pro Tools compatibility table would let you run with an officially supported Pro Tools 12.8. but I would personally not do this, especially as Avid have delivered significant enhancements and improvements in Pro Tools since then, including in plugin processing in 2019.5 and later.
Hopefully you have not been doing all in-situ upgrades to that MBP, if so, if you want to run say 2020.5 on it on Catalina with least chance of issues I would first do a full clean install of Catalina. And you should be aware of the Pro Tools quicktime issue on Catalina, described in the release notes.
  #17
Old 07-08-2020, 09:42 AM
JFreak's Avatar
^^ what he said.
Janne
  #18
Old 07-09-2020, 04:04 AM
Originally Posted by JFreak View Post
^^ what he said.
Ok, thanks for your response. I think the best option would be upgrading to Pro Tools 2020.5.
I’ve attached a screenshot of supported processors...Will I have any issues running PT 2020.5 on my MBP considering the processor speed is 2.8 GHz? (Mid 2017 15" MacBookPro14,3 Quad-Core Intel Core i7 2.8 GHz) It’s new, so should be clean already.
File Type: jpg Screen Shot 2020-07-08 at 1.52.37 pm.jpg (49.4 KB, 0 views)
  #19
Old 07-09-2020, 04:08 AM
JFreak's Avatar
It is 2017 so unless you have done a clean install of Catalina, it is upgraded install.
Janne
  #20
Old 07-09-2020, 04:33 AM
It was bought refurbished. I'm looking into whether it's a clean install or upgrade now. Any idea if the processor speed will be an issue? Considering it's not listed with the supported processors?
You dont have any Licenses in your account Rudiekazu2 Licensing & Accounts 16 10-10-2017 09:47 AM
Too Many Licenses in Account kcsound Licensing & Accounts 1 08-11-2017 10:28 AM
One or more licenses to surrender cannot be found manymax Licensing & Accounts 12 04-06-2017 12:00 AM
The license Pro Tools 10+9 Bundle [Avid] requires surrender of the following licenses Kin3tix Pro Tools 10 1 05-06-2013 07:15 PM
