Re: My sessions all seem to crash, plugins are too much...external hardrive?
thats one of the main reason's i didn't go out right away and get a external because I figured the ssd would be enough
What happens if you disable the plugins and add one at a time to see if one of them are bad and need updating? Also try open up thesame session with the focusrite interface disconnected and usethe internal soundcard. Then we know what if any issues are with Focusrite drivers.
by monitors I meant the mbp screen and another monitor through hdmi i know that stuff is probably not important but I'm throwing everything out there in case something sticks and I find out what is going wrong, I know it has something to do with the plugins but I don't know why, when I start up and hit select and all of them are inactive it works fine and responds great but, no matter what I do, erase old preferences, Reinstall everything, it just doesn't work, I have even started a new session and imported the other tracks and session info into that one, I have tried a new log in account on my mac, I have fixed permissions and the drive just about everything I can think of
I have done that, and sometimes it will work when they are off and I add amplitube it crashes then I'll take that out and it works fine then I'll add amplitube again and it will work, then I'll take out ez drummer and it works then it won't I mean it just picks and chooses what plugins work and don't work, I have used the eleven plug in from avid, that seems to work, but if i use boom or something like that it will stop responding as well, so I have tried adding one at a time, but it doesn't seem to be giving me the same responses consistently
What settings do you have in the buffer size for example. If you use heavy VI you might need to set the buffer to 512 or higher.
Also if you ONLY use the internal soundcard, pull out the Focusrite? AND - Try all these variations with NO HDMI connected as sometimes PT will revert to HDMI and think thats a interface and horrible things happen.
#16
I bumped the buffer to 512 disconnected the focusrite and hdmi and same thing as soon as the session opens, it starts spinning and says immediately pro tools not responding when I do the option command esc, when I say immediately i mean some of I don't even get a chance to move the mouse sometimes before it happens, maybe I should reinstall pro tools again for the 7th time, I'm running out of ideas, maybe my computer is shot, I fix the permissions and when I verify the disk it says its fine...Its either that or the computer doesn't like me, I never did anything to it though lol
#17
ok well I'm at 5 minutes on this session and it hasn't crashed YET with the HDMI out, what I did was started pro tools holding shift, then turned one back on at a time, saving it right after each one was turned on, I don't know if it is solved but this is the longes the session has been working for like 2 days now
#18
even if I don't get this fixed I want to thank you very much for helping me
#19
I still suspect that the problem lays with the HDMI monitor as PT sometimes jump on the HDMI and looks for a interface so leave that out for a while and do the testing. If it doesn't crash then we know that the HDMI connection is the culprit.
#20
ok well fingers crossed, thank you again
External Hardrive? | WillTaylorMusic | Pro Tools TDM Systems (Mac) | 2 | 04-17-2006 11:16 AM |
External Hardrive -- what should I buy? | beebs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-24-2005 02:22 AM |
External Hardrive -- what do I buy | beebs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-23-2005 12:32 PM |
Firewire Hardrive Crash-Any Hope? | swpowe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-27-2004 04:05 AM |
external hardrive???? | werds mekani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-19-2003 09:58 PM |
